2fast4bmw »
https://forums.nicoclub.com/2fast4bmw-u163830.html
Mon Jul 05, 2010 10:06 pm
Road noise, what kind of pavement are you driving on? I had a car from a friend and he had a very loud road noise, out by him, not by me! MMM I checked the tires, the bearings , etc, What was it? a combination, They have bluestone roads out east by him and we have smooth ones in by me. Also he had OLD tires on the car, so this was his problem. Now if your front tires are old noise travels in unibody cars, you will not locate it as easy as the old cars in the day with a frame. Also check the pressures with a good gauge, and remember for every 10 degrees of temp change, you gain a pound or loose it, hot up, cold down. If you want to get crazy, try Nitrogen it is used in the Nascar stock cars and all new cars that have "green" valve caps, it is not effected by heat or cold.
