If the cloud is out of the exhaust then it could be a head gasket or even a cracked head. Need to fix what you know is wrong and hope for the best.flyhighusa wrote:hey guys,
have a G35 with a major overheat problem
I can only keep it from max. heat all the way pegged up. when I drive on the interstate if I hit any traffic it will spit out the coolant from the boiling reservoir. so far I can't detect a radiator leack. I shut the car down in time
- driverside radiator fan not working (checked the 40a fuse ok)- passenger side radiator fan works accordingly- ac is kept off and cabin temp full hot with windows open to relieve engne strain however the ac doesn't blow cold air anyways and cabin full hot just blows lukewarm air
what could my prblem be? can't find the temp sensor that controls the radiator fans.
- where do I find those sensors?- is my waterpump faulty?- faulty engine thermostat?
it takes about 10min to overheat real quickly and gives the people drivng behind me a nice cloud of coolant vapor.
thanks a million for any suggestions. !!!
- Sander
G35 coupe
cloud is from overboiling coolant reservoir. smells great thanks for reading. I appreciate all the help.pfarmer wrote:
Perry
fan closest to resrvoir works. checked the fuses. can't check wiring yet. you think it would be the single fan or replace them both?tollboothwilley wrote:It is your fans. They just can't keep up with the heat. You need to replace them. Its one of the most common reasons that G35's overheat. Just replace the fans and you should be good to go.
Ok so the ECU controls both fans, since one of them does kick on on-demand i'm assuming my ECU is good. I'm going to try and use the wiring of the working fn and see if the other fan works. just by splicing it. worse come to worse I'll leave it spliced and running until I order a replacement fan unit.tollboothwilley wrote:The fans run off the ECU. ECU tells the fans when to kick on/off.
I read it. Head gasket leaks can and do show up in both your exhaust and also your reservoir. You stated when you hit traffic but you didn't state if it occurs when you slow way up, as in almost a stop or simply when you slow down. If you have a blown head gasket then you should be able to detect exhaust in your reservoir.flyhighusa wrote:
If you have a head gasket leak, your combustion pressure is often higher than your coolant pressure so the combustion gasses will flow to the lower pressure circuit and end up in your reservoir. To check you can use a meter or even your nose. The smell is different than that of hot antifreeze.tollboothwilley wrote:Perry, how can you detect exhaust in your coolant reservoir?
Another method:tollboothwilley wrote:Perry, how can you detect exhaust in your coolant reservoir?
I believe he is stating the same as myself which is combustion gasses.tollboothwilley wrote:those gasses come from the exhaust...right? Or are you saying they come from somewhere else?
I am told that I could have air in the system still, maybe I need to bleed AGAIN??
This could be number 3 especially if it had been in use during hot weather with a faulty cooling component.Poyzinous wrote:I have only seen head gaskets fail in 2 VQ motors my whole life. Its rare. you can also use a carbon monoxide/nox detector in the coolant. those gases leak into the coolant as well.
I have never had a water pump impeller fail. However I have had the shaft seal fail and have seen this many times. This can be a source of air into the system. Keep in mind that if you get air into the system that it will blanket various parts of the system keeping water from coming in contact and carrying the heat away. You can actually have your coolant drop in temperature or increase. It may increase since the engine will get hotter and the coolant will then pick up more heat in the areas it does contact. It becomes sort of engine area contact area issue. The air will also displace the coolant. In much the same way as steam will make your coolant lever appear unnaturally high when in reality the system contains less water air will do the same thing and continue to do so until it is vented.tollboothwilley wrote:I'm running aftermarket fans (stock was mechanical fan). Maybe I need to have them start and stop earlier? I had to replace my radiator this summer...started leaking.
I've been told that the water pump doesn't go out very commonly but it is an option.
Many people that have issues with heat creeping up at all can be attributed to air in the coolant lines. I have burped the system a few times.
Coolant levels have dropped maybe a cm every so often, which is my concern. Aside from that no issues.
Just took the tstat off, not sure how to really check it though. Spring works and valve is closed when i took it off.tollboothwilley wrote:Water pump is the bottom on the passenger side I believe.
Have you checked the T-stat? That may be sticking. Its one of the cheaper things to try first. You could have air in your system if you have done anything with the fluid.
