pfarmer wrote:
I have never had a water pump impeller fail. However I have had the shaft seal fail and have seen this many times. This can be a source of air into the system. Keep in mind that if you get air into the system that it will blanket various parts of the system keeping water from coming in contact and carrying the heat away. You can actually have your coolant drop in temperature or increase. It may increase since the engine will get hotter and the coolant will then pick up more heat in the areas it does contact. It becomes sort of engine area contact area issue. The air will also displace the coolant. In much the same way as steam will make your coolant lever appear unnaturally high when in reality the system contains less water air will do the same thing and continue to do so until it is vented.
If concerned I would do as I suggested or use some other method of looking at coolant temperature so you may be able to associated it with what you know occurs. For example you know that your thermostat (at least if it is functioning correctly) starts to open at a certain temperature and is fully open at another. You know your fans start at a certain temperature and then shut down at another depending on their bandwidth.
What I have found out for example is that the thermostat on my car (stock) appears to start to open around 178 or so and will be fully open by 190. the reason I think this is true is that it will cycle between these termperatures up to the point the ambient is high enough that the termperature will then rise up to around 195 (ambient around 104). On my temp gauge this isn't all that much needle movement but easily viewable with the OBD gauge.
Perry
this describes exactly what's going on. unnatural high coolant level. have to bleed the system every time ( bled it with front end high for more than 3 hrs ) though I cannot detect any leaks would it be possible the shaft seal is shot and sucks in air but not blow out coolant?
it gets hot and all of a sudden it drops to normal temp range some times. ac kicks on and then off really quick.
is there a description how to tackle the replacement of the water pump? this would be HUGELY appreciated thanks so much for all the info this is actually fun.
Modified by flyhighusa at 11:27 PM 9/13/2009
