G35 Fuel gauge Problems!
pdelvecc
Car: 2005 G35 Coupe
Yeah. Hi guys. I'm new here to this forum. My name is Paul. I have an 05 G35 coupe. And I've been struggling with my fuel gauge. Not reading correctly run out of gas too many times to count. I've seen the videos on YouTube tried cleaning. The sending units with Q-tips put the instrument cluster in diagnostic mode and fuel gauge Falls. Between a half a tank and a quarter of a tank, so it doesn't make it all the way up to a half tank. In diag mode. I don't know if that means my gauge is bad or what but this problem is driving me absolutely bonkers. Would appreciate some help.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Q451990 wrote:
Tue Oct 03, 2017 8:59 pm
:welcome: to NICO! Today seems to be bad instrument cluster day. Google "instrument cluster repair" or search for that on eBay. There are multiple vendors that rebuild clusters. I don't have any experience with them, but the going rate seems to be somewhere around $100-150, so not bad compared to Infiniti's solution, which would be to swap the entire cluster.
Fuel Level Sensor
2012 G37x Gas Gauge shows 1/4, but...
Gas gauge and miles to empty difference
kenman3000
i had the same problem. spend A LOT of time troubleshooting and debugging. at the end this worked for me. i have a 2007 g35 coupe 6mt. will take some good soldering skills but its a zero-cost solution
https://g35driver.com/forums/g35-sedan- ... led-5.html
MobileTechGundam
Car: 2004 G35
2019 Nissan NV200
Hey, I've seen issues related to fuel level indication for years now. 2 common problems for this. The fuel level sending unit, and the cluster itself. These days if a g35 rolls into the shop, we recommend they replace both of them. Because too many times someone will replace the level sending unit, and a little while later the cluster fails and they run out of gas again, and create a scene at the dealership. So we cover our a** by replacing both and eliminating any possible issues.
