joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Mon Mar 05, 2007 7:10 am
I have an 05 with the Bose system...The rear 6x9s are full-range speakers. The Bose setup uses the rear seat 6.5" speakers for bass. If you were to add a sub, that is the speaker leads you need to use for the input.
I would take the car to a stereo shop (not best buy or circuit city) and have them install everything. Most amp companies are coming out with decent amps that can use speaker level inputs or low-level (RCA) inputs. Personally, I love my MTX amp and sub set-up. I still have room in my trunk, but no fold down seat access.
Some will disagree with my setup, but replacing the mid/high speakers doesn't give you the bang for the buck as adding a sub.
Anyway, you're best bet is to look in your rear deck for mounting holes. Most 6x9s will come with a grill, so pick one that matches the ascetics of the interior of the car.
I agree with PoorMan Q...get a decent component set instead of the 6x9s, the sound is much smoother.
