G35 Cold air intake??
maticc
Car: 2006 infiniti G35 black coupe
Hey im lookin to put a cold air intake on my 2006 coupe g35im trying to decide between AEM, Injen, or K & NAnychance anyone has any of these intakes and could give me some adviceim looking for the intake that will1.Provide the most HP/Torque gain2. Sound the best3. And is most reliablecan anyone give me some tipps????
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
All good options
Lots of people have the Stillen or the JWT popcharger.
Have you tried a search?
I don't think i've heard anything bad about the reliability on any intake. Sound is preferential.
cheapazz
Car: '05 G35 5A/T coupe
Love my Injen!
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
I have the NISMO CAI for the Z on mine. Fits perfect and sounds great. I noticed gains in the upper RPM range.
tollboothwilley
This is my preference. Don't mind the majority of then engine. There's a lot of work going on. It'll look hawt when i'm finished...
V6 G35s
Car: 2008 G35S Loaded,Black,Cash NO PAYMENTS !!! $28,000 OTD
Im pretty new here but back in dec when i got my G35s i put a set of injen intakes in it and i love them
joker350gt
tollboothwilley wrote:This is my preference. Don't mind the majority of then engine. There's a lot of work going on. It'll look hawt when i'm finished...
dang man clean the bay lol
dougiefresh7988
Car: 2005 infiniti g35x sedan
2008 infiniti g35xS sedan
maticc wrote:Hey im lookin to put a cold air intake on my 2006 coupe g35im trying to decide between AEM, Injen, or K & NAnychance anyone has any of these intakes and could give me some adviceim looking for the intake that will1.Provide the most HP/Torque gain2. Sound the best3. And is most reliablecan anyone give me some tipps????
have you tried a alternative brand intake for your infiniti i have a 2005 g35x sedan and i put a fujita short ram intake on it this intake sounds awesome with my stoks exaust and gave me about a 10 to 20 horsepower gain . it is priced reasonalby at under 300$
joker350gt
dougiefresh7988 wrote:try
tollboothwilley
10-20 HP from an intake huh? Anybody else think this man is fooled??
joker350gt
tollboothwilley wrote:10-20 HP from an intake huh? Anybody else think this man is fooled??
im working on a mega thread for intakes and exhaust coming real soon
donkim1
Car: 2003 G35 Coupe 6MT
i have an AEM intake. it added a nice little boost but not really noticable. it sometimes gives off a high pitched whiny sound. i'm not 100% convinced that its from the intake but its what i've been told
dougiefresh7988
well buddy got a dyno ill drive my a** over ther to prove it ur username says it all you F$#&*% joker
G_whizz
Car: 2010 G37 Coupe Sport
Jesus... kewl out with the name calling.. grow some thicker skin.
pfarmer
Car: 2008 GXS with technology package
dougiefresh7988 wrote:well buddy got a dyno ill drive my a** over ther to prove it ur username says it all you F$#&*% joker
Or you could post your dyno. For the 07-08s it looks like it does work and work fairly well, however the published dynos only show about 5-8 hp gains.
Perry
uprev
Most of the intakes available for the G/Z are going to be short ram style. The "cold air intake" design is flawed in design but seems to work well in marketing.
Plus the gains are proven with the Stillen Z tube, and JWT PopCharger setups.
Personally I say go with what you think looks the best if thats what you're looking for. If you're looking for power gains in an intake then you should think about doing something else as the stock intake is actually fairly well designed. Also if you change the way the air flows over the MAF (which most intakes will do) you should consider getting a tune that will readjust the MAF. The MAF is the basis for the entire running of the motor and if you cause turbulence at the MAF you can lose power in any number of spots in the power curve.
The better choice for the DE motor G/Z is to get the plenum spacer. You're smoothing the air flow in the plenum, not affecting the tune drastically, and it's an inexpensive mod.
The HR and VHR motor cars don't really have intake issues thus far. The twin intakes by design will offer much more flow capability, and much more accurate distribution of air in the plenum. The stock power curve on the newer motors is pretty damned smooth because of this.
uprev
Forgot to mention.
If you're going with an oiled filter material that you'll want to buy a can of CRC MAF Cleaner. http://www.crcindustries.com/a...05110The oil from the filter gets into the air stream over time and messes with the MAF reading. You'll want to clean the MAF every oil change as a preventative measure. Better safe than sorry when it comes to the MAF.
Dry filter material is the better choice for keeping the air clean going into your motor. Most new dry filter material has very little resistance in air flow, and you don't have issues with the oil getting on the MAF.
Point of contention to all the K&N lovers out there. K&N recently purchased AEM's intake division so they would have a dry element product to sell.
GWhiz35
Car: Infiniti G35 Coupe
I bought the JWT pop charger w/ Z-tube and have been pretty impressed with it. It comes with a heat shield too. I probably gained 5-7 hp out of it and it makes the car scream at WOT! I've had an INJEN intake before but it was on a 00 Celica GTS and i saw a big improvement.
joe603
Car: 2014 Durango R/T
Be careful when handling your MAF sensor...they damage VERY easily!
cheapazz
With the Injen intake, the filter is located just in front of the drivers tire. During install you have the option of cutting away some foam (which is recomended from Injen) or just remove that piece of foam for a direct shot of air to the filter. The other nice thing about the Injen is that you can remove the lower tube to use it as a short ram intake for the winter so as not to clog up your filter with sand or get water in it. It sounds great and you can feel the gains, but I'm sure you will feel gains with just about any upgrade over stock. It is as close to putting your filter outside of your engine bay as you can get.
tollboothwilley
I actually opened up a air hole in the radiator support directly in front of the Stillen air box. I might enlargen that some as well. It will give you some direct cold air.
I read some tests that were done on outside air temp. 18" off the ground was much hotter than 18"- 36" that they measured in the tests. Keep that in mind when thinking about air intake design.
toddnos
Car: 2003 infiniti g35 sedan
lol at this guy^^^^
tollboothwilley
Some peoples kids....
MisteenoMike
uprev wrote:Most of the intakes available for the G/Z are going to be short ram style. The "cold air intake" design is flawed in design but seems to work well in marketing.
I've personally witnessed a short ram intake make more power than it's Cold Air version on a G35 VQ35DE equipped with a NISMO R-Tune Cold Air Intake System. On the dyno the intake with cold air extension gained an average of 3.2hp (with a 10hp dip in power at 3800rpm). After converting to short ram, power jumped to 5.6hp (with no dip in power).
This is due in part to intake resonance. Injen is the only company that tunes out this resonance with their "step-down" process in the built-in MAF housing included in most of their newer intakes. What's "flawed" with most other companies Cold-Air kits is that they use the same diameter pipe from end-to-end, which does nothing to stop this resonance.
Almost all companies make excellent performing Short Ram kits as resonance is more of an issue with longer pipes. But only Injen's Cold-Air kits are tuned properly for maximum gains. So if you go Short-Ram get whatever floats your boat, but for a CAI I have a hard time recommending anything other than Injen based on what I saw on the dyno.
joe603
Interesting...this seems to make sense!
Welcome to NICO!
apro06g35
Car: 2006 G35 Coupe
Maticc-IMO stillen airbox/ztube is the way to go im really happy with it have an 06 as well
Jacob_USA
Car: G35 sedan 05
I looking something for my new G35x sedan 2006
So Stillen is much better or Fujita, JWT, AEM ??Wich one's better??
xjaywalker
Car: Orange County, CA
06 G35 Sport Coupe Prem NAV
Welcome to NICO. Fellow RSM resident! Thank you for the info, still not sure if I am sold on CAI at $300, but that was informative. Are you the new Silver G I 've seen around?
MisteenoMike
No, sorry, I don't own a G. But a customer of mine (who also happens to live in RSM) has a Dk. Blue Metallic G35. That's the car that I witnessed the power improvement on after converting it to short-ram.
Instead of splitting hairs trying to get 1-2 extra ponies with a CAI, with the money you save, get a short ram + plenum spacer and make some guaranteed horsepower!
dougiefresh7988
love my fujita i think it is great , sounds awesome with stock exaust will sound even better with performance exaust , and easy to intall best of all wont break your wallet check them out on ebay if any or andysautosport.com best of luck to you
Doug
