fujita or aem?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
xtremeversa
Car: 2007 Nissan Versa Hatchback
which is better as far as performance for the versa? ive heard everyone talking about both of them... but lets get to the real scoop... which one's better? and whats the difference between them?
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
with all the speculation floating around about how fujita uses oil filters, which is not true at all... it uses dry filters just like aem... theyre very similar in many ways... and im almost for certain the power gains are the same as well... imo why pay the extra money for same product?
NorCal_V
Car: 2008 Versa Sedan S
I have to say Fujita, and I say that because I believe it's more of a "complete" aftermarket piece. I have not seen the AEM in person, but from photos it's obvious that you must reuse parts from the stock air box setup. For instance you will reuse the little accordion looking plastic elbow between the throttle body and intake from the stock setup, and you will have to reuse the stock PCV setup as well ( which is a big ugly black plastic thing.) This is not so with the Fujita, you change everything out and it all comes in the box. Instead of reusing the accordion, you get a nice 4-ply silicone hose to replace it. As well they supply a silicone hose to replace the stock PCV system and there is a port on the Fujita to hook that up to.
Now as far as the performance advantage, I don't think that there is one to speak of. Either one will likely give you the same amount of power increase. The only differences to speak of are the fit and finish between the two. You will be happy with the power increase anyways.
Modified by NorCal_V at 10:52 PM 10/6/2008
Johniboi
Car: Versa
Did these intakes come out at the same time? or did one come bfore the other?
NorCal_V
I don't know I just started looking at aftermarket parts for my V about a month ago. At that time they were both available. I bet the guy at Versaspeed would certainly know.
2dr_sentra
Car: 1997 200SX SE-R, 2007 Versa SL 6spd
When i buy mine, im buying the fujita hands down.
BlueMango
Car: 2008 Nissan Versa S Hatchback
The AEM intake does reuse the accordion piece that you refer to but I thought it made the installation easier.
As for the filter, Yes, fujita uses a dry filter. AEM's DRYflow filter has an efficiency rating of 99.52% "based on independent SAE J276 JUN93 FINE DUST Air Cleaner Test Code procedures". Fujita doesn't even state their filter's efficiency rating...maybe cause it's not very good.
I've looked at the Dynos from both companies and it appears that AEM wins with 1 extra torque.
superskunk
send me the link to the aem dyno sheets please...
superskunk
#1Tango
ya but check this out
zerothread?id=258129
Johniboi
Car: Versa
AEM ROCKS! end of discussion
NorCal_V
Holy #$%!, where the heck did he get a 132 lb. ft. of torque to the wheels? He is running that BRM exhaust system right? Damn!
BlueMango
+6 TQ
+4 HP
And I agree with tango.
#1Tango
NorCal_V wrote:Holy #$%!, where the heck did he get a 132 lb. ft. of torque to the wheels? He is running that BRM exhaust system right? Damn!
that was before the exhaust. that is an old thread
superskunk
for the price of the aem... blah.... fujita!
#1Tango
prices went up now :-P
Return to “Versa Technical Discussions”
