But overall I'm happy with the look so far on mine:
edwin711 wrote:Looks real good is that a brembo brake kit. Are the wheels replicas or oem. Do u mind sharing what they cost you
have any pics of your car without the fender work done?ctsedan wrote:You sure these are off 2010 GTR, I know the 2010 wheels have +20 all around, but the 2009 are +25 rear and +45 front. I got 2009 and had to find all 4 fronts with +45 to run on my car, i didnt want to do any fender work.
Not yet, Im actlly using the set up as my winter wheels combined with OEM RFT Blizzaks. Its a very good fit, Im dropped on Teins. Ill try to get some pics.BlinG* wrote:have any pics of your car without the fender work done?ctsedan wrote:You sure these are off 2010 GTR, I know the 2010 wheels have +20 all around, but the 2009 are +25 rear and +45 front. I got 2009 and had to find all 4 fronts with +45 to run on my car, i didnt want to do any fender work.
OP - love the look....wheels look sick
Actually no not 100% positive, I'll ask the guy. Can discern by looking at the markings on the wheel? Everything I found re: the wheels is that all the rears, 2009 - 2011, are +25.ctsedan wrote:You sure these are off 2010 GTR, I know the 2010 wheels have +20 all around, but the 2009 are +25 rear and +45 front. I got 2009 and had to find all 4 fronts with +45 to run on my car, i didnt want to do any fender work.
Car looks great!
Anyone looking for 2009 rear GTR wheels I have 2 wheels with tires and tpms. pm me
edwin711 wrote:Those must of cost u a fortune look good. Where u grab the bbk from?
cool...mexillis wrote:usually on the inside it will say ET## for ur offset inside the spokes.
ctsedan wrote:Here is mine with +45 all around, which is the front wheels from 09 GTR.
what tire size did you go with in the rear to not have rubbing and no body work? Just purchased the 2009 GT-R wheels..I am looking for some insight. I am on eibach springs.kermit the guy wrote:car looks good !! your running 275 in the rear , i too was running 275 and i had rubbing just a ta when i rode 2 people in the back , so i went to a smaller width and went lower and no more rubbing and no fender work !that sucks what they did to that skyline!!! they did that to my bros car , took the rims and just dropped it on the spare tire dumb idiots!!!
what would you suggest for the front tires? stock size?mexillis wrote:^ 245/35/20 or a 255/35/20 will work
i was thinking of just getting 245/35/20 all around, but i tested fitted the wheels and the rear wheel sticks out about an inch and a half. so im afraid even with that stretch the rears wont fit. Is it possible to throw more camber with out having to get adjustable camber arms/ control arms?mexillis wrote:Stock tires from a gtr have a larger rolling diameter than ours so I wouldn't personally use them. The sidewall thickness is to large and over 3% in difference. It all depends on what look you want for you set up, if you want the stretched look all around go with a 225 upfront and 245 in the back. There are numerous ways to go. 245 all around or 255 all around, that would give the most sidewall protection and have the least amount of stretch.
