fuel, spark but won't start
240-drifter315
Car: 1991 nissan 240sx 1990 wide body hatch
i have just finished me sr swap into my 91 240 but it won't start. It has fuel and spark but just cranks. any help would be great
1992s13_drift
Car: 1992 Nissan 240sx
check your timing. Thats the most common problem.
namdaman
Car: 1990 Nissan 240sx
double check the wiring and make sure your maf is working
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
+1 for check the timing
GORDON
What is the correct way to set the timing?#1 cylinder and the second mark from the right mark on the pulley? Then turn the CAS till they match?
ficodecko
Car: 1993 240sx se with sr20 and way to much money into it
http://www.frsport.comfir the timing guidealso make sure all your wire connections are solid mine did the same thing till i fixed a loose connection in the harness
GORDON
Thanks guys, It was the CAS. Seems it was off, realigned it and it started. Kool! But now no oil pressure. Seems a new oil pan is in order...HUH?
josephg15
Car: 1992 240sx
my car is doing the same thing...fuel, spark just cranks and no start...my timingis perfect. i just reset the cas and im going through my harness again...hmm...**** i dont know whats going on
IanS
GORDON wrote:Thanks guys, It was the CAS. Seems it was off, realigned it and it started. Kool! But now no oil pressure. Seems a new oil pan is in order...HUH?
just pull off the one you have and hammer the hell out of it
josephg15
Car: 1992 240sx
hammer it? im not a hack....ill stick with the good old diagnosis BS
iwantasileightysr
Car: 91 rps13
turn it to the left so you advance your timing 1 degrees from tdc (top dead center of piston #1) which is indicated by the 0.
cylinder 1 should fire right after it hits that mark
josephg15
Car: 1992 240sx
turn the cas sensor right?
GORDON
LOL... Ok yea took the oil pan off and straightend iy all out, Got oil pressure now.
Toook the CAS out and realigned it, seem it was way off... Started and runs like a champ.
Now we have a different problem... seems the BOV won't close and air leaking through, worked fine for a day or so. any way to adjust it? "Geddy type RS BOV"
josephg15
Car: 1992 240sx
question?? how did you align the cas wrong? i thought mine is aligned right and i didnt start, so i am going to do it again...thanks
IanS
josephg15 wrote:hammer it? im not a hack....ill stick with the good old diagnosis BS
I meant to hammer the oil pan, at least he understood me, I dont think a hammer would fix a CAS
iwantasileightysr
Car: 91 rps13
