j.hardstyle wrote:Alright...so you are saying just unplug the vacuum hose going from the solenoid to the canister? And if that doesnt work then what?
One thing i want to mention....i just replaced the o-ring for the fuel pump and all 6 bolts that hold the fuel pump down because 2 bolts were missing originally. When i looked in there the first time, i did notice that there was one hard line off to the right side all by itself that was not tightened down. The flare nut was off and the line was just sitting in the fitting that comes off of the fuel tank.
I am not sure what that line is, but i connected it like it was supposed to be because i was having issues with a fuel smell in my car. I thought it was because of that line not being connected and also the fuel pump not being bolted down properly (due to missing bolts and the oring).....but when I pulled the pump, gas leaked all in the trunk so it smells like gas in there now anyways.
But i am wondering if that line that was not hooked up has something to do with the noise?
j.hardstyle wrote:I found a fuel probably causes poking around the trunk today....it helps that I have another Q now to compare to.
I found the red rubber line disconnected (that runs from the filler neck to under the trunk, in case of fuel spills)...I connected it. Also, I removed the fuel tank completely from my 94 and noticed that there are small o-rings on the hard lines, and they butt up against the fittings on the tank itself. I dont remember ever seeing these on my 92....and I have been seeing some bits of moisture/vapor being around the fittings, so I can only assume that is attributing to the fuel smell as well.
Regardless, when my new fuel pump comes in, I will be putting it into the fuel ta nk I just removed....removing the fuel tank thats currently in my car and swapping it out. Put all new o-rings where the fuel lines go into the fittings and then see what happens after everything is put back together.
The reason for swapping fuel tanks is because the one in my 94 is shiny and looks to be untouched...all the fuel pump bolts are there, the tank was still stuck to the floorboard with that sticky s***, the fuel pump harness still had the shrink wrap, etc. I know it has not been messed with. On the other hand, the tank in my 92 is white and corroded looking...I know it has been removed previously (possibly even swapped from a different car) because the sticky crap at the bottom of the tank is not original (its broken up), the fuel pump harness doesnt have the shrink wrap and there was originally 2 bolts missing to hold the pump down, AND not to mention the fuel overflow hose wasnt even connected!
Fuel pump has finite life based on amount of hours operated,just like any other electric motor that uses carbon brushes- brushes wear down to the point they no longer make electrical contact and pump stops operating- so, yes time/miles operated is a key indicator of remaining pump {motor} life-rabsusa wrote:j.hardstyle wrote:I found a fuel probably causes poking around the trunk today....it helps that I have another Q now to compare to.
good observations! one thing i ll note reg fuel pump - it is NOT an item that can assessed by miles on the car or apparent miles since last change. my bro has my 94 Q1, i had from new, never had anything in it other than 93 octane, (oil only synth btw) and has always been refueled at 1/4 tank mark, suffice to say he is on the very same FP. When runnng on constant E mark here in Fl ("poor owners") i seen them go out in as little as 2 yrs,
rob
