CMG »
https://forums.nicoclub.com/cmg-u54511.html
Sat Sep 15, 2007 8:39 am
Did you replace the fuse and relay because they were not working. If the fuse was fried, that means it shorted at some point, and you may not have fixed the short. Keep an eye on that fuse, and if it keep getting fried you still have the short. By the way, if someone tried to snag your ECU, they probably knew it was an SR, which means it could be someone you know.
