turbocarslut »
https://forums.nicoclub.com/turbocarslut-u2129.html
Wed Jun 13, 2007 5:05 am
I need your help. I have been having problems with my vehicle not starting for a while. I checked spark and signal to the injectors with a noid light. All checked out. I suspected I had faulty injectors so I went and bought new SARD 550cc injectors, and a Megan FPR with gauge. I put everything in and still Nada.
One thing I did notice now was the fact that my fuel pressure goes to about 5psi and falls back down to zero when I put the key in the position right b4 I am about to crank. I hear the fuel pump turn on and then what sounds like fuel falling back into the tank (quarter tank of gas in the car and quiet garage) My question is this...when you take the key to this position shouldn't fuel pressure go all the way to 43 or whatever you have it set at and HOLD the pressure? Do fuel pumps go bad if the car has not been used for an extended period? It is a Walbro 255lph pump in there.
Oh...I checked for fuel leaks in and around the fuel rail. There is no fuel dumping into the cylinders or coming out elsewhere. The injector and FPR setup is leak proof.
