ca18coupe »
https://forums.nicoclub.com/ca18coupe-u131297.html
Mon Dec 06, 2010 2:55 pm
I just installed a type a nismo adjustable fuel pressure regulator. I have a 0-100 psi inline fuel pressure gauge, i looked online for a digital fuel pressure gauge that has a decimal point to set the base fuel pressure to 36.3 psi, but was unsuccessful at finding one. So my question is how is everyone else setting base pressure? What kind of gauge are you guys using? Would setting the base pressure at 36.5-37 psi ( where it is probably set at the moment ), cause any problems other then a slightly rich condition, or is it going to be a problem until set 100% as per factory seeing as I'm running the stock ecu? Not driving the car right now until i know for sure it's safe. All help will be greatly appreciated.
