fuel pressure and boost question ??
squarehead
Car: nissan
should i run higher fuel pressure if i run higher boost ? stock is what ? 7psi boost and fuel pressure (with vacuum hose off) fuel pressure regulator is 43.5 psi ?? so if i were to run 13psi what should be the fuel pressure be set to with an adjustable fuel pressure regulator ??
sydwayz315
Car: 92 240sx
technically you should start by getting a wideband o2 if you don't already have one. but to answer your question you should start out by unhooking your vacuum to fuel pressure regulator then start out at 50psi and just turn it down little by little untill it's not too rich. don't go let then 43psi or you will be buying a new motor....
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
You should set fuel pressure to 43.5 psi with the vacuum line unhooked, engine idling at normal operation temperature. The pressure should drop to 36 psi with the vacuum line connected. With stock injectors and a T25 turbo you can go as high as 13 PSI before injector duty cycle becomes worrisome. It is also good to note that the T25 will go out of effecientcy above 14 PSI, and the stock MAFs reaches maximum flow around the same time.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
I am reading 37-38psi with the vacuum line hooked up. Should I turn it back to 36 or is there any advantage/disadvantage to unhooking the vacuum line and going to 43.5?
