Fuel line question
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
2 things.1)What size fuel line goes from the filter to the rail and back down the return line. I measured mine at it was 1/4", is that right? I figured it would be 3/16".2)Does either side (feed/return) line need to be able to do high pressure or no? In other words, do I need to get high pressure fuel line (expensive stuff, $5/ft, at parts stores) or will regular fuel line (the $1.30~/ft) work?And yes, I've searched.
Hijacker
Car: '92 240sx Convertible
'94 F-150
1/4" sounds correct to me.EFI systems pretty much require the high pressure lines. The line's going to see 43+ psi most times.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Hijacker wrote:1/4" sounds correct to me.EFI systems pretty much require the high pressure lines. The line's going to see 43+ psi most times.
Use the high pressure stuff.
