Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Mon Feb 16, 2015 6:33 pm
The rubber hose connection between the filler tube and gas tank is original.
That's the way it's designed.
Same thing with the vent tubes.
They are all connected via hose clamps.
The filler tube is metal, with a plastic protective coating.
The plastic coating splits/deteriorates over time.
Water gets in behind the coating through the splits, and rusts out the tube. Then it leaks gas.
If you remove the rear wheel, and then the plastic shroud over the filler tube assembly, you'll see it all.
I suspect the rubber is OK, and that it's the tube that's rusted through.
I was able to re-use the clamps, even after 12 years.
