4cefed »
https://forums.nicoclub.com/4cefed-u1486.html
Sat May 19, 2012 10:15 pm
Well I don't have a 300, but I'll try and help. Do you have pics? I searched for some new ones on Rockauto and amazon, although they don't show pics of the end of the plastic bit, I'm going to say that's the sleeve/seal from the injector to the intake manifold. With some injectors they will direct fuel toward the intake valves, so their orientation matters also. Did some get stuck in the intake manifold when you removed them? Again, pics would help. If you try and reinstall the injectors without them, bad things will happen. Vacuum leaks, fuel spraying into the engine compartment, loose injectors... you get the idea. You could try getting a set from a salvage yard or some new ones for around $50 a piece.
