2 o-rings sounds correct. is the injector NEW, or rebuilt? i don't trust used injectors, and 'rebuilt' are still used. at a minimum, i would order the correct o-rings from one of our sponsors (i'm partial to scottsdale (everything____.com)) hmmm, you have a G20 and you posted in NOM? no matter, SR20DE.
still don't know what you mean about melting. don't forget to lube the new o-rings. buy a fuel pressure tee and check for pressure leakdown.
zerothread?id=232571
