Q45tech wrote:Indiana? Are you in an area with oxygenated fuels? This will drop the city mileage by close to 10% [for sure 5% minimum].
You said 14 mpg EPA is yours a Q45a [active car]?
To spend less, and extend your fuel pump life, always fill when your tank indicatior reaches the ¼ full mark. Running it until empty or near empty stresses the fuel pump, causing it to fail sooner. It's in the threads.elwesso wrote:spending $40 to fill up is killing me
Woodmister wrote:That Honda Insight lookin nice right about now isnt it?![]()
6speedG35sedan wrote:I just put a K&N airfilter in my 03' G35 sedan and did the first oil change and went to Valvoline Syn Pro and this last tank of gas I got a true 1.5 miles more per gallon. I'm getting 20 mpg combined city and Hwy. What do you guys think of synthetics and K&N?
elwesso wrote:What i do to fill is i wait until half tank, and I alternate between premium and mid grade.
greg_atlanta wrote:Anything less than 91 octane will make mileage worse. I'd stop alternating gas types.
Does the car ever get strenuous exercise? Just running around town forever is BAD for a Q45. A road trip with a can or two of good injector cleaner will make a world of difference. Engines that never get hot for long periods of time get crudded up very fast. (intake and injectors)
Get a professional intake and injector cleaning done too.
When you read the posts on oil (we have some very technically qualified people here including TexasOil and Palmerwmd, among others), you will learn the advantages over standard oil stocks.elwesso wrote:Synthetics- If the car doesnt call for it, what is the benefit. I put in what the MFG says.
While doing some research for someone, I came across information that California's gasoline supplies are under greater pressure than refining capacity can handle because of the increasing number of SUV's bringing down over all fuel efficiency and the growing amount of distances being driven on an average trip.msscomm wrote:And all this with that California sulpherd up, oxegenated 91 octane crap we have the priviledge of paying through the nose for (San Diego is just about the highest in the nation @ the pump) - Thank you soooo much to Govenor Grey Doofus and all the CA eco-wackos !:bash
VimyJ wrote:I don't know if you are old enough to appreciate it but when I was a kid visiting S. Cal in the late 60's and early 70's the air pollution was staggering. You could notice the smog when looking across a typical lawn to a car in the street. It's much better now than 20 years ago thanks to better fuels, cat. converters and cleaner burning engines.
msscomm wrote:Averaging about 15 to 16 around town with the 96 Q - and I DO have a very heavy foot - 20 to 22 on freeway trips of several hundred miles -
elwesso wrote:What should I do to determine the if all those things are what they should be? It seems to run smoothly.
Do you think spraying a little TB cleaner in there would be a good idea??
