Vegascorbin wrote:Do you knoe the RPM you were at when it cut at 75MPH?
approx.. 3400rpm in 5th, 4200 in 4th, 5k in 3rd
And when you put the car on jackstands and run it through the gears it DOES NOT cut out?
Correct, I can max out in all gears.
Am I correct to say that the regular Rev Limitter DOES kick in at around 6500?
Yes, which lets the car still be fun/safe in 1st and 2nd
It has to do with the ECU determing that the car is under Load and having to make active corrections to the Fuel rather than looking at a predetermined fuel map.
The $64,000 question is what has changed from original as these cars were able to run with "active" fule when new.
my friend with the s14 is stupid even after i told him not to change the speed sensor from his s14 transmission cause it wont work he preceded to do it and in turn has no speedo alsoproject blackout wrote:ok so i had a 89 s13 that got ran over by a jacka$$ in a 4 door chevy pick up, so i took the speedo and the speed sensor out of that and put it in my new 89 s13 and it fixed my fuel cut, dash lights and heads up. the only thing i can think is that it has to show the speed along with a good working speed sensor for the ecu to get a good reading and work right. i hope this helps everyone else. it seems like no matter what everyone had a fuel cut and no speedo. i think i have a extra heads up if someone needs it, holla at me.
