fsm question
240driftguy
Car: 91 240 sx
when looking at exploded views such as the rear suspension it will point to a bolt then show a bunch of numbers, are the first numbers the torque spec and is in ft lbs or nm because it doesnt say
vancouverbc
Car: 1991 240sx
240driftguy wrote:when looking at exploded views such as the rear suspension it will point to a bolt then show a bunch of numbers, are the first numbers the torque spec and is in ft lbs or nm because it doesnt say
all are torque specs in 3 diffent units of measure. each diagram tells you that.
vancouverbc
Car: 1991 240sx
1991-1993-240sx-rear-shock-replacement- ... 70768.html
240driftguy
Car: 91 240 sx
in order what are the units because I don't see where it tells you which one is which
The last one is lb-ft. It's usually a range, such as 75-80 lb-ft.
Hijacker
Car: '92 240sx Convertible
'94 F-150
The legend for which number is which is usually in the lower corner of the diagram.
