FS full megasquirt II v3.0 setup built,wired,and ready for ca,already tuned too.
jrsink
My spun ca block is getting picked up this weekend.I stilll have the transmission, nissmo transmission mount and nissmo engine mounts for sale.(mounts retail for $260)
I was originally planning on replacing the CA with a ka24de with itb's and running it on my current megasquirt setup.recently tho, i had been thinking i might just do a ka-t, instead of NA KA with itbs. i can put together a whole ka-t setup for a round 500 bux,and run low boost (with a cheapo FMU),to achieve my goal of 200-250hp on a ka-t.
there is TONS of info, wiring diagrams, pics here on NICO, on this built meagsquirt II V3.0,ford EDIS4 ignition setup that ran my previously mentioned ca18det. hey!! here's the write up actually:zerothread/164446
It used to be THE CHOSEN ONES car.i bought the car untuned with everything setup by him running, but running crapy (becuase it was untuned, and running on what seemed like a ford mustang base map?idk).
I then had the car tuned at ZFEVER with the megasquirt setup,ford escort EDIS4 ignition,walboro fuel pump, wideband,FMIC and a t28 pulsar turbo at 8 pounds it made 223 hp. (8200 redline btw).I spun a bearing about amonthafter the tune, bc im a retard : ) nuff said.im moving on now.back to a high torque ka <3
i have seen these complete setups go for around $500 on here untuned.i paid approximately $900 when it was all tuned at ZFEVER.-about $400 just for dyno/tuning-about $400 to program all the CA basmaps and values into the box.(megasquirt II V3.0 box (unbuilt) with ford EDIS4 retails for about $650)---Megasquirt II - $250 Stimulator - $40 Wiring Harness Supplies - $130 (Includes wires, crimps, tape, solder, fuses, fuse block etc etc) Megaview -$110 (optional) GM Open Element IAT - $21 (optional stock sensors can be used, but megasquirt comes set for GM sensors) GM Closed Element Coolant Temp Sensor - $FREE (optional stock sensors can be used, but megasquirt comes set for GM sensors)(megaview screen (unwired) retails for about $110)
TAKING OFFERS NOW. sink 8134584209 call or textill make a greeat deal if someone wants it all, id rather not break it up.comes with everything mentioned EXCEPT crank trigger wheel, bc it was pressed onto the crank and im selling the motor to BRADT (on here) this weekend. I am very reasonable on pricing. bc its just sitting around not getting used. and i need money for my new setup : )
8134584209 call or text. will ship
jrsink
looks like buyer (BRADT) is flaking on picking up the CA18det spun motor today.250 for ca18det minus valve covers, turbo/intercooler.100 for transmission and clutch stuff.300 for all of it.
(YOU WILL NEED:-bearings~ 60 bux.-valve cover ~50 bux.-turbo/intercooler ~100 bux.=~$200 you can have a running ca setup)THIS IS A SUPER GOOD DEAL FOR SOMEONE THAT WANTS TO GET A CA cheap. 8134584209 call or text jason
someone buy this stuff. or else i may be forced to build this thing into a 300-400+whp MONSTER
wynnEZ
Car: 90 240 CA POWA!
Whats the best price you can take on thw whole setup.
jrsink
wynnEZ wrote:Whats the best price you can take on thw whole setup.
500
davidricardo86
Car: 1992 Nissan 240SX SE
So, $500 for the entire megasquirt setup minus the crank trigger wheel?
jrsink
davidricardo86 wrote:So, $500 for the entire megasquirt setup minus the crank trigger wheel?
yep : )
the_momo
Car: 1997 VW Golf K2 (His)/ 2001 Black Lexus IS300 (Hers)
just curious if you still have the megasquirt setup, i believe once the taxes come in (should be about a week) i will pick this up ( my ca has no harness, and id like some tuning flexibility, so its a natural option)
anyhoo, is it running on a maf setup, map sensor or what? just curious.
thanks!
also, if you do have it still, would you take 400? im pretty sure that i can come up with, 500 maybe not.
jrsink
im keepin it sorry
