Alright due to a huge request I've finally gotten around to doing this write up to all you CA owners looking for a standalone system that is far superior to your normal ECU.This write up is gonna be for your basic CA18DET into a 240sx and utilizing the FORD EDIS-4 ignition system and Megasquirt II.
DO NOT HALF *** any of this, I REPEAT DO NOT HALF ***.
Before we begin lets compile a list of what is needed, what options their are, prices, etc etc. I will indicate what is optional.
You have your choice of Megasquirt I and Megasquirt II as well as V2.2 and V3.0.
I suggest going with Megasquirt II V3.0, yes its a little more expensive like $80 more but will make life a little easier and it allows the use of Low Impedance injectors without the need of a Flyback board that is required with V2.2 boards. Also V3.0 has the flyback board built in so thus why V3.0 is the choice to go.
One of the places I recommend getting all your Megasquirt kits, parts, etc etc. is http://www.DIYAUTOTUNE.com Jerry is probably one of the biggest help and dealers in the megasquirt community. His kits are properly labeled and more organized than the other dealers.
Also as a note I will not take responsibility for your actions, so if you mess up your board, engine, car due to unexperienced, human error well tough but I'll still try and help you out.
Another note if you dont know how to solder parts onto a board, go to radioshack get yourself a practice kit.
Now that, thats out of the way onto to the write up.
Some Parts can be found at junkyards and pocketed ( I do not recommend stealing of any type)
Parts Needed:
Megasquirt II - $250
Stimulator - $40
Wiring Harness Supplies - $130
(Includes wires, crimps, tape, solder, fuses, fuse block etc etc)
Megaview -$110 (optional)
GM Open Element IAT - $21 (optional stock sensors can be used, but megasquirt comes set for GM sensors)
GM Closed Element Coolant Temp Sensor - $FREE (optional stock sensors can be used, but megasquirt comes set for GM sensors)
http://www.DIYAUTOTUNE.com sells wiring harness kits in which all you have to do is splice the sensors, fuses, relays and your good to go.
They even sell assembled ecu's so if building it scares you they do have you taken care of for a price.
This is the Megasquirt Kit.
This is the Stimulator
FORD EDIS-4 List:
FORD EDIS-4 Module - $Free at local junkyard.
FORD EDIS Tower CoilPack $23 at Junkyard
FORD EDIS VR Sensor - $Free at local Junkyard
FORD Tower Spark Plug Wires $Free at local junkyard
FORD Trigger wheel - $Free at local junkyard
FORD Radio 25uF Suppression - Comes with Coilpack harness.
FORD EDIS CoilPack bracket - Comes with coilpack (needed to ground whole coilpack)
Thats all for the EDIS parts. Make sure when getting the ford parts you get the harness with atleast 6" of wires.
The FORD EDIS-4 parts can be found on 1991-1995 FORD Escorts.
The module is located on the driver strut, coilpack is a few inches away you cant miss it. The VR sensor and Crank Trigger are on the passenger side of the motor. The Crank Trigger is pressed on but with a big flat head screwdriver and hammer should pop it off with several hits. Everything is inside the engine bay.
Here is a pic of everything.
Now that the parts list is complete onto Assembly of Megasquirt II.
I'll be straight forward and say when you get the kit, your gonna use all of it except several pieces. When you look at the kit you'll see lots of holes etc etc. On the board each spot has letters and numbers.
For example if it says R13 on the package that means that piece goes to R13 on the board. Also the letters give you a idea what piece is that for example R stands for Resistor, D stands for Diode, C stands for Capacitor etc etc.
NOTE: Some parts are actually polar sensitive for example some Diodes have a line on it, if you look at the board it also has a line where the diodes go match those lines up. Same goes with the IC sockets theres usually a notch on it just match it on the board.
Here is a picture of the V3.0 Board components.
Here is a picture of the components you must not install.
NOTE: D1 and D2 must not have a Diode but you have to jumper them. You can use wire, sniped of lead. Both have to be jumpered. Leave C30 and C12 empty nothing goes their.
| Quote, originally posted by Megasquirts site » |
On the V3.0 main board: use the 'Hall sensor circuit' (step #50 in the assembly guide), jumper OPTIN to TACHSELECT on the bottom side of the PCB, near the DB37 connector, opposite the heat sink, jumper TSEL to OPTOUT on the bottom side of the PCB, near the center. jumper JS10 to IGN (this uses the processor port for the SAW signal directly), jumper XG1 to XG2 on the bottom side of the PCB, near the 40 pin socket,
Once that is done, Megasquirt will be ready for EDIS. Now you may install the the MSII chip which is a daughter board.
Do not power up megasquirt yet via the stimulator. Make sure the MSII daughter board has a jumper on it. Most of the time the dealers already put it on for you but they dont install the code for you.
Before powering up Megasquirt you need to download a program to burn the code to megasquirt. The program can be found here.
http://www.not2fast.com/megasq...p.exe
After downloading and installing the program your not done yet, you need to download the code its found here.
http://www.megasquirt.info/ms2/code.htm
Their are 3 files. You only need 1 which it says at the moment.
| Quote, originally posted by megasquirt » |
DB37 pin #36 to the SAW pin (#3) on the ignition module DB37 pin #24 to the PIP pin (#1) on the ignition module
Dont worry about Pin 7 on the EDIS module you can delete it, the ground is inside the shielded wire for the wires that go to the VR sensor and Megasquirt.
Some of you guys might ask what about TACH, good news take pin 2 from the EDIS module and just wire it to your Cluster harness, wire it to the Yellow/Red wire which is your tach wire and thats it. I did it and its acurate, I checked 2 rpm sources from Megaview and Megatune all were dead on.
I decided to use GM sensors as megasquirt comes set to use GM sensors. If done properly you should only need to drill and tap one sensor which is the GM Coolant Sensor to replace the stock sensor. The stock sensor is M12x1.75, the GM sensor is 3/8 NPT. Everything else is set to go. Also for the Intake Air Temp sensor I purchased a Open Element IAT sensor. Open is suppose to be used on Turbo/Super Charged motors as the reading are faster and more responsive.
Fuses.
I added a Fuse block instead of tapping into the stock fuses, this made for a clean setup and seperate from the car. The fuse block is only for Megasquirt so any trouble shooting is cake. They can be had at local parts store for about $3. Fuses not including.
Here is a pic of my harness, along with how I set it up.
That Should give you a idea of how I set things up.
Now to wire the fuel pump its extremly easy. When coverting to Megasqiurt do not throw away your KA harness, you might need several plugs. If you look were your stock fuse block is near the stock battery. Look for a brown plug which has 8 prongs. Its E10 in the 1991-1994 240sx FSM in the EL section at the end in the wiring diagram section. Once you locate that brown plug look for the wire that is Black/Pink take the megasquirt fuel pump wire which is 37 on Megasquirt and wire it to the Black/Pink wire and thats it, fuel pump is done.
Now your main relay, I cheated and just spliced into the ignition switch harness. I spliced into the Black/White wire, but after the plug it becomes Black/Red. So you can splice into that, you can take the power wire from megasquirt and the module make it into one and splice into the Black/Red wire. You will need to eventually add a fuse and relay between those wires.
Thats it for Wiring. Next comes Hardware.
Hardware:
I REPEAT DO NOT HALF *** especially this part.
The trigger wheel which is a 36-1 (36 minus 1) tooth wheel. So its 35 teeth with a gap.
One of the things you need to decide is where and how your going to mount the trigger. I mounted mine on front of the crank, since I'm not using power steering, I had a machine shop mill down the front of the crank and had it pressed on. You want the GAP to line up with marks on the crank pulley which is the 2nd mark for 0* TDC. This is important because with EDIS-4 since its a 4 Cylinder you need to set it 90* ahead which is exactly 9 teeth ahead of the gap. Makes sense to use 90* because in a 4 cylinder each 90* represents 1 cylinder. This link can provide more info on EDIS if my write up isnt as clear or if your a little confused.
http://www.megasquirt.info/ms2/EDIS.htm
Here is a pic of my Trigger mounted.
After the Trigger is properly mounted. Its time for the VR sensor and bracket. I'm not gonna lie to you, its up to you to figure this one out. Just remember it has to be perfectly centered on the 9th tooth, and it has to be
0.030" - 0.060" (.75mm - 1.5mm) away from the trigger wheel. If you look where the alternator and crank pulley area you'll notice 2 bolts. I used those 2 bolts for my bracket. Came out nice.
I'm sure their are other ways to set it up, I believe Not_a_Sr will be working on a megasquirt setup and could probably offer services for VR brackets and modified pulley's. So dont be scared the CA community will be getting more support.
Now its time to move onto ignition such as spark plug wires, and coilpack. Well if you saw my previous picture I have my Coilpack mounted inside the cabin and made a hole for the spark plug wires to go through and onto the motor.
DO NOT CRANK YET.
After all that is done pretty much the rest is buttoning up everything and cleanining up. After your all set and everything is good, go ahead and turn the key to Accessories check everything is good, then check On see if everything is good, check for fuel pump priming.
After you got all Greens go ahead and connect the computer to megasquirt you need to do a TPS calibration. Turn the key to when megasquirt gets power but doesnt crank, you may disconnect fuel pump harness just in case.
Open up Megatune click Tools>Calibrate TPS
where it says Closed just click "Get Current" Now go WOT and click "get Current" I believe it should be like 1500 somewhere in the 1000. After that is done go ahead and crank it it should fire up, if not try going back and checking mistakes. Dont forget to reconnect Fuel Pump if disconnected.
If it runs congratulations your done, only thing left is tuning.
I will post videos Sunday of the car starting and idling along with Megaview.
Hope this helps some of you guys. If some of you guys are interested I'm offering megasquirt services.
