Well all the stuff in my signature was done. Last summer, (or 2500 miles ago) I did all that work to my Q. Changed the plugs, cleaned the MAF, the TB, the EGR, the inside of the plenum, changed the fuel filter. The fuel pump does buzz a little, but has for years.maxnix wrote:Well, Dan, you know the drill.
What have you done? ...How old are the plugs? Fuel pump? Fuel filter?
It's very noticable at idle, even my wife noticed. At constant cruise it's not really that bad, I'm not sure if I can even feel it. Under heavy accerlation you don't notice the shudder, but the power's not there like it should be.maxnix wrote:Is this only at idle and constant cruise, or is there a miss under acceleration loading?
Now that you mention it I'm afraid it's an injector problem. I was hoping it was the MAF last night. (At least I know the spare MAF works.) I haven't tested them. There was a thread by goody somewhere that talked about that...maxnix wrote:Ohm tested the injectors?
That's the sort of question I'd ask, but on this forum, I know there are only two answers:AlabamaDan wrote:How about this question - Will driving 600 miles with a bad injector damage anything?
Well you know I care about my Q, but I'm stuck between a rock and a hard place. I am running M1 oil and filter. It was changed less thatn 3k ago and still looks nice and clear.Q45tech wrote:I wouldn't do it personally if I cared about engine but who knows.
I saw that code 21 on a 95 Q with intermittently failing injectors... I'm not sure that a dead injector won't trigger that code as well, since an open injector should look the same to the ECU as an unplugged one.goody94q45 wrote:You're doing it correctly and the reading on #4 means you have a dead injector. When you pull the codes if you get an "injector signal circuit" (code 21) it means that the connector to the FI has come unplugged or the harness is bad. If you see code 45 (Injector failure) it confirms your injector Ohm readings.
It's in his signature line... about 150K - but I think you have those turned off.maxnix wrote:Dan, you didn't state your mileage, but at 100K or so, every plenum needs to come off to get clean.
I agree.....mine is gone if it develops injector or transmission problems, cant see sinking $2500-3000 for new OEM injectors that will not last as they have not improved the construction to eliminate the problem, or the value in dropping 3k into a new transmission.....and then have the injector problem rear its ugly head.....so whichever goes first{injectors or transmission} spells time for the Q retirement partyoldmako wrote:Hi Dan. That sucks.
From reading it sounds as though the Ethanol is the chief culprit in injector failures and if that's the case then we will all have to adjust to frequent replacement. All of the discussions I have read thus far indicate that the pre 96 cars seem to be particularly prone to injector issues from ethanol.
I bought my car last fall and it has run great ever since (just over 12000 miles). Virginia has been pumping ethanol for years and it has been screwing up lots of machinery aside from cars. Boat fuel tanks for example. Should my 99 start eating injectors I will get rid of it. I love the car, nicest one I've ever owned but the hassle and cost involved will overcome all it's appeal.
My 96 chevy truck has the original injectors and has 230,000 miles on it. I am willing to spend a fair amount of time and cash on getting my old Q nice, however I will not invest that time and energy for a recurring and expensive problem.
