Slumpert wrote:Sounds more like bad ball joints to me.
If the wheel bearings was loose you could easily wiggle it in any direction
I am also suspecting bad ball bearings.. there is no wiggle if i put one hand at the 9 o'clock position and the other hand at the 3 o'clock position and shake the wheel.
If i put one hand at the 12 o'clock position and the 6 o'clock position and shake the wheel i can feel the wiggle. There is no noise, only a clunking noise when going over bumps....
If I am going to replace the ball bearings i should replace the lower control arms and get alignment done.
