Front Wheel Bearing Noise???
dgielow
Car: 2006 M45 Sport
Hi Everyone.
Can someone help me. I have a 2006 M45 with 87,000 miles.
Overnight I have noticed a noise coming from my front left wheel area. At first I thought it was my Bizzaks getting worn down. But I took my vehicle to my Infiniti dealer b/c I was worried it was a bearing issue.
They claim they put a stethoscope to the wheel and did not pick up any strange noise and said my tires were cupped.
I just purchased 4 brand new tires and the noise is exactly the same. Zero difference.
The noise is most noticable above 45 MPH. At highway speeds I have found out that the noise is the same if I'm going straight or going thru a right hand curve. But a left hand curve will make the noise quiet down substantially.
I drive tons of highway miles and certainly cannot afford to have something like this go bad on me...
Any idea's...could this still be a bearing...or something else?
Thank you,
Dan
M4T5
Car: 2007 Infiniti M45
Take it back to the dealer that told you the problem was the tires. Show them you replaced the tires due to their "fix" to the issue. Take the tech or service adviser for a test drive with you and make the car duplicate the noise. Your description sounds just like a worn hub bearing by the way.These dealers are sometimes really quick to avoiding taking care of the customer the way one should be taken care of. I've noticed this varies quite a bit per location and dealers attitude. Take it back and make sure you show them they were wrong and their misjudgment cost you money out of pocket for no solution to their problem they stated. Good Luck.
J
DRIPS
Car: 2003 Infiniti M45
I also think this is sounding more and more like a wheel bearing
Tekmazter
Car: 2003 M45
I had something similar ... found out the mechanic put only 1 of the 2 bolts back in the caliper so the caliber was bumping down on my rotor while driving.
Put the 2nd bolt back in and the noise went away.
I too thought it was a bearing at first ... but generally speaking when I've had bearings go in older cars of mine growing up there was always a grinding sound you could hear inside of the car or a dull roar if you will.
dgielow
Car: 2006 M45 Sport
OK...got the car fixed yesterday!
It WAS a bearing! Just like we all thought. The first time the dealership looked at the vehicle they spun the tire on the lift at about 70 mph but the noise did not show up b/c there was no weight/load placed on the tire/wheel.
The second visit they actually took the car for a road test and found the noise right away!
You guys were a huge help...thank you for all your input and ideas!
The cost was $430...I thought that was reasonable considering the other prices I've seen dealerships charge for this...$400-$550 from my basic research.
They also recommended a fuel injection cleaning service...that was $120. Did I need that??? Who know's...but I thought after almost 90,000 miles it couldn't hurt!
Thanks ag ain!
Love this forum!
Dan
M35 Sport
Car: Infiniti M35 Sport
dgielow wrote:OK...got the car fixed yesterday!
Thanks ag ain!
Love this forum!
Dan
I have an appointment at the dealer this Thursday for a front left bearing noise in my car. My warranty is still in effect until July 28 so I want them fix any and everything they can find. I initially thought my tires might be the problem. However I have replaced one tire, and rotated and balanced all of them. The noise is still there. I will drop it off and get a loaner Thursday afternoon. I also ordered a new un-cut key off e-bay yesterday. Hopefully they can cut and program it while working on the wheel bearing.
SHREVE66
Car: 2003 M45
Walmart does the exact same fuel system cleaning that other places charge 100.00 +. They do it for around 30.00.
New2Import
Car: 06 M45
I got both replaced today. Also getting a oil consumption test started. I check the oil and it was almost at mid point with only 1700 miles since the last oil change.
M35 Sport
zer...noins
Anybody have and Ideas?
747driver
Car: 2006 M35X, 2007 Porsche 911 C4S, 1997 Jaguar XJ6
Thanks ag ain!
Love this forum!
Dan
How long did you have to wait for a new bearing. I have a bad front wheel bearing on my 2006 M35X, as diagnosed my dealer on Apr 20. They ordered a bearing and scheduled the service for today. This morning my dealer called and said they couldn't get the bearing and are expecting it on May 8. Does this sound reasonable to anyone? Car is under warranty.
Mark
747driver
I visited my dealer this afternoon and after a heart-to-heart conversation with the owner regarding my disappointment with the service and my request for a loaner car for the next 9 days, the wheel bearing magically arrived at the dealership today and will be installed on Friday.
BMacd1
Car: 2008 M35x
The local dealer replaced both of the front wheel bearings on my 2008 M35X about a year ago, while the car was still under extended warranty. I just started hearing the familiar noise from the right front wheel. Any suggestions as to getting Infiniti to make good on this?
06M4.5
Car: 2006 M45
I just saw this and the price is too good: :gotme
http://www.amazon.com/dp/B00DMA64BO/?ta ... ail.com-20
I may call them next week.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Premature wheel bearing failure is a common problem with Infiniti vehicles. Your powertrain warranty should cover the wheel bearings.
06M4.5
Car: 2006 M45
Amazon is out of stock
So who has the best price on the oem front hub-bearing for the y50?
part # 40202-ej70a
TXT
Car: 2006 M45 Sport
06M4.5 wrote:Amazon is out of stock
part # 40202-ej70a
Did you try this one? http://www.amazon.com/Timken-HA590125-A ... 0202-ej70a
Autozone sells that part for 289.00 on their website. Autozone also says that it will fit 2008 and 2009 m45, but not 2006 and 2007 which I don't think is true....but maybe it is.
It's also Prime so it will get to you pretty quickly if you have prime. I may be wrong all together and the part I linked you to may not even fit.
06M4.5
Car: 2006 M45
Is Timken oem or aftermarket?
Best price I seen for oem is $159 ea
rxmclaren7
Car: 2006 Infiniti M35x
i was wondering how hard it would be to do this on my own...replacing the hub bearing?? mine is going and i need to replace it soon...
TXT
Car: 2006 M45 Sport
06M4.5 wrote:Is Timken oem or aftermarket?
I believe it's aftermarket brand, but the following is one of the reviews from amazon for that item:
"Appeared to be manufactured by same as OEM Nissan parts
Easy to install and not had any issues of yet
Recommended and Thumbs up to Prime 2 Day shipping
2005 Infiniti FX35 AWD ;) "
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
you can try OC Infiniti's ebay store...I saw the price and drove down to pick up the parts...they honored the internet pricing. OEM part
I think I paid $300 for everything...tax included no shipping :biggrin:
06M4.5
Car: 2006 M45
I just ordered a set thru ebay from an Infiniti dealer in Atlanta $296 shipped.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
Freddie - link to your purchase? thanks
06M4.5
Car: 2006 M45
I was lucky to get the last 2pcs from a total of 12 sold.
You have to call the parts dept and ask for the person in charge of the ebay ads. Give him your vin # and ask for the part # for your car.
My 2006 M45 RWD part # is 40202-ej70a for the front
ebay seller: gwinninf
Infiniti of gwinnett of Atlanta
888-347-8018
Good luck, Freddie :dblthumb:
06M4.5
Car: 2006 M45
I forgot to add that I paid $147.90 each with free shipping :yesnod
dwdickson
Car: 2006 M35X
rxmclaren7 wrote:i was wondering how hard it would be to do this on my own...replacing the hub bearing?? mine is going and i need to replace it soon...
I just did mine yesterday. Only real difficulty was I broke the head off the bolt holding the speed sensor. Otherwise the repair is pretty straight forward. I found these DIY instructions by asavage very helpful:
how-do-you-diagnose-wheel-bearing-noise-t468291.html
Best of luck!
06M4.5
Car: 2006 M45
How long did it take you to do each side?
I'll be doing it on the ground with no air tools :frown:
dwdickson
Car: 2006 M35X
I only did one side (other side done by my mechanic a couple of years ago). I'd say it took me two hours or so except for the broken bolt which cost me another couple hours get supplies and fix. This was with hand tools in my garage. Now that I've done it once I think I could do it much faster. It's not a complicated job but the rusty bolts after 135K miles were a little stubborn.
rxmclaren7
Best of luck!
thanks for the info!! but as i dont have a place inside to do the work i am going to take it to my mechanic and have him do it! he says it will only cost me $ 350 for him to do it parts included!! that and he knows what he is doing...i do but i get nervous when it comes to my car for some reason!!
dwdickson
Car: 2006 M35X
That sounds like a good price. I recall paying about $425 a couple of years ago.
SleepSmithY34
Car: 2003 M45
HELP!!! Looking for Y34 replacement Front Wheel Hub Assembly - Lft and Rht for 100K mi 2003 - M45 Y34....Have found bearings online - but would prefer DIY ease of installing Whole Hub Assembly myself - IF can get a reasonable costs Assembled Hub. However, have Not Been Able to Locate Y34 complete Hub Assembly anywhere..??? ....Have tried eBay, RockAuto, Beck, etc .....Any Help in finding reliable 'reasonable' seller source Greatly Appreciated....don't want to be 'raped' by dealer.....ugh!!!:-) Thanks
