steve_c »
https://forums.nicoclub.com/steve-c-u163301.html
Thu Oct 15, 2015 9:51 am
Good question TDot!
As you can see, wheel bearing noise is largely mis-diagnosed as tire noise. Many threads are written about shops telling owners "it's tires!" resulting in $$$tires, and no change in noise! Pretty shameful on the part of these lazy incompetent shops!
As far as tires vs bearings, I sometimes swap tires to determine if they are the culprit, if I have any doubt! A bad tire will drone like a bearing, but will usually not change pitch under various loads (turns) as a bearing will. A bad tire, moved front to rear, can usually help in diagnosis since you will feel the noise "move" slightly from where you originally heard it emanate from.
A lightly worn bearing will mostly show itself as a medium frequency drone usually at speeds 20+mph & above. This drone may may become more pronounced or reduced in a turn, especially notable on highway on / off ramps. As the bearing wear progressives, the drone usually becomes more pronounced.
Rocking a wheel and turning a tire by hand are not effective in diagnosing. Usually a worn bearing will not "click"; however, a worn drive-shaft joint will!
A severely worn/damaged bearing will produce a grinding noise. That's easy! At this stage, it is also easy to determine what side is bad.
For the most part, it is only after to old hub is in your hand that you can tell if it is worn. (turn it by hand back & forth).
About our cars; specically M35x's;
I find from this & other forums that front wheel bearing failures typically can occur as early as 70k to 87k miles. I had mine fail at 85k miles!
I made an error in my previous post, I confused L/F & R/F. It was my R/F that failed, which is typical, as the R/F is curbside & usually takes more abuse.
Steve_C
