Front Passenger Window Goes Up Then Down
RoyDaGeneral
Car: 2002 Infiniti QX4 2WD
I'm having problems with my front passenger window. I push button to close it, but when it reaches the top, it drops down by about 2" I've disconnected the battery and tried keeping my finger on the switch. This started happening after programming a new key fob. Did I mess something up in the process? How do I fix this? Thanks.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
try this push the DOWN power window switch and hold the button for about 5 seconds after it is all the way down, then roll up window and release the switch
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The '04's have a "reset button" that you need to remove the door panel to access. Raise the window all the way manually, then press the button and run the window to the bottom while holding it. Use the first (manual) switch detente while doing this, don't use the second (auto) detente position or it won't take. On some models the door switches also need to indicate doors-closed while timing the windows.
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
Yep, VStar650CL knows of what he speaks. My passenger has needed the reset twice, so I'm well aware of it myself.
One added note is in case you can't get to it right away, the way to get the window all the way up is to only push the switch to where the window starts to go up. It's a 2 position switch, first is it moves but only while you're holding it, the second is all the way up, the "auto" function.
RoyDaGeneral
Thanks guys, your suggestions fixed the problem.
VStar650CL
Technical Expert
You're most welcome, happy motoring!
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
That reset process is in the stickies somewhere BTW. It's a known quirk that can be fixed in 5 minutes.
Here's another link from a few years ago that goes into greater detail.:
help-with-adjusting-window-auto-rolldow ... 20741.html
