MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Wed Aug 27, 2003 6:49 am
To back up RYanT-so long as you HAVE the license plate in the front and it's somewhat visible (and it is, I've seen it in his car) when the cop comes to check it out, he's not gonna care. And this is ASSUMING you get pulled over JUST because of your license plate, because if you get pulled over for something else, unless the cop is a real d1ck, he'll be behind you and not go up and check out your front to make sure it's there.
If the cop says anything about it not being visible, you simply say that you have to go and get it mounted at the body shop or something bc your bumper doesn't have holes--(Well, this may not work for other 240's, since my stock s14 bumper DID have the holes, but there's no way in hell i'm drilling through my beautiful nismo bumper)
The way to mount it on the windshield is to take 2 small suction cups, available at a hardware store, slide the plate in flush to the windshield, put the suction cups through the TOP mounting holes of the plate, and stick it to the window--that way it is fairly visible, and it won't rattle....
