Front Brake job- m45
DRIPS
Car: 2003 Infiniti M45
what size are the 2 bolts on the torque member to remove the caliper assembly?
I forgot and cant find it in the manuals...i just want to make sure i have the right size socket before pulling off my wheels
RAGTPZ
Car: 1993 Nissan 300ZX Twin Turbo Convertible, 2010 Infiniti FX50S
DRIPS wrote:what size are the 2 bolts on the torque member to remove the caliper assembly?
I just did this not too long ago and can't remember myself but I think it is either 19 or 21mm.
M4T5
Car: 2007 Infiniti M45
22mm front and 18mm rear.
J
DRIPS
That big. Yikes. I need to go get a new socket! You just saved me a little upset!
M4T5
M4T5 wrote:22mm front and 18mm rear.
J
That is if your wanting to remove the main caliper bracket from the spindle. If your doing a complete brake job (new or turned rotors/ new pads) this will have to come off either way.Good luck man!
J
DRIPS
OK. Im heading outside to do this! Here are the pics of my parts.
DRIPS
which rotor goes on which side? what way does the slots/drills go?!! HELP
Jimmyz
Car: 2007 M45 Sport
The one on the right goes on the drivers side. What brand are the rotors. I did this today as well. I used CTec rotors and Akebono ceramic pads.
Modified by Jimmyz at 6:00 AM 1/19/2009
DRIPS
OK, job went smooth. Here are some pics of the process.
old rotorscaliper offbrake linenew ebc rotorsnew pads loaded and mounted calipercompletedpad view
M4T5
DRIPS wrote:which rotor goes on which side? what way does the slots/drills go?!! HELP
They are stamped R & L.
M4T5
What brand rotors? Power slot or EBC?? I see the Hawk pads. Looks good man. Let us know how well they stop. Make sure to follow the break in procedure first!
J
M4T5
DRIPS wrote:OK. Im heading outside to do this! Here are the pics of my parts.
You should work in Advertising!!!! Love the parts display!
J
tytamto
Car: 2006 Infiniti M45
What brand of rotors? How much? Where did you get them?
Good looking brakes
DRIPS
zerothread/394697
Its all in this other thread I posted.
tytamto
Duh!
Thank you.
DRIPS
FYI- gold zinc plating is already warn off (2 days of light braking) where the pads connect to the rotor surface. No big deal as that is the last place for rust and the zinc is for rust, but geeeezzz I liked the gold!!
Jimmyz
Car: 2007 M45 Sport
DRIPS wrote:FYI- gold zinc plating is already warn off (2 days of light braking) where the pads connect to the rotor surface. No big deal as that is the last place for rust and the zinc is for rust, but geeeezzz I liked the gold!!
That's totally normal. I had cadmium plated rotos on another car and that was great. Stayed silver forever.
szh
Car: 2018 Tesla Model 3.
Did you thoroughly clean and regrease the caliper pins? They will stick otherwise and degrade the pads too quickly!
Z
M4T5
That's a good tip for everyone, but that's not what caused the coating to wear away. It wasn't intended to stay on the rotor surface (pad contact area) once it gets used. I too used these on my previous mustangs and my last two Silverados I had. The coating will wear off, but it should stay coated where the pads do not touch the rotors though. Drips, is it still on the remaining parts of the rotors where the pads don't touch them? It should be. The whole reasoning for the coating is to resists rust from forming.
J
DRIPS
Yes it is. My point was solely for where the pads touch and I knew it would wear, but it was so fast!
szh
M4T5 wrote:That's a good tip for everyone, but that's not what caused the coating to wear away.
I agree!
Sorry I confused people. My point was a general one with pad or rotor replacement, in regard to cleaning the caliper pins when you do this, since sticking calipers is often the cause for future faster pad wear or brake failures, not rotor wear.
M4T5 wrote:It wasn't intended to stay on the rotor surface (pad contact area) once it gets used.
Yup! Mine gets "cleaned" of rust in that area every time I brake ...
Z
