Sorry for being a little late. A boost leak test is the only way to really check for boost / vacuum leaks. Just watching the boost / vacuum gauge will not give you any info unless you have a baseline to compare to.rlvq35de wrote:
vacuum seems good. 22hg? at idle
Is it safe to go above the 43.5 to get the idle afr in spec without safc correction?Even tho the tune is for 43.5lbs
I will chk resistance to make sure im withing JWT specs 10-14 with the msd injectors. Im using the 72lbers since that is what the base tune is for esp since im new to tuning.
Fuel pressure changes will make global changes in fueling. Upping the base fuel pressure will give you more fuel everywhere. Rom tunes like JWT will only get you close due to so many variables in peoples setups. Using fuel pressure changes and air / fuel controlers will get the tune dialed into your combo of parts.
I wouldnt worry about checking ohms in your injector circuit. It is fine the way it is with either set of injectors you have.
