If your ecu is already tuned for that maf then you wouldn't need to change the in out settings to 5-5 right?rlvq35de wrote:neo is at 5 in 5 out grommets are brand newjwt tuned for z32 maf
I'm not 100% sure on the Neo, but my SAFC-II is 2 in for the Z32 MAF. And if your ECU is already tuned for a Z32 MAF, you need to put it back on a number 2 out.rlvq35de wrote:neo is at 5 in 5 out grommets are brand newjwt tuned for z32 maf
Which injectors do you have in now? What is your fuel pressure set at?rlvq35de wrote:i Have to add 26 value in fuel to idle at correct afr 14.5 at idle
Fix any vacuum leaks you might have then adjust the fuel pressure to get your idle AFR. Use your SAFC to tune your drivability and WOT.rlvq35de wrote:
Ivan, Fuel pressure is 34ish at idle 43-44 with vacuum off, it was low, I just set it at that.
Now feul correction is only 22 at idle.
The resistor pack adds 6 ohms of resistance to what the injector has. You should have 8 ohms with our 75 lb injector inline.rlvq35de wrote:Ivan
What does that Mitsubishi resitor pack bring the injector resistance value to? JWT is warning me not to run the car with it cause i will burn our the injector drivers. I dont believe that.
Correct me if im wrong, unplug ecu harness, unplug injector to test, and see if the resitance is 10-14 ohms?
It seems to be running fine without JWT 10 resistors.
