its a 5 inch screen. It would be nice for it do be a little larger. but sitting in the car your so close to it it doesnt seems small. ill keep this updated as i go on
Agreed.. im 16 too and my 240 DOES NOT look that great.S13AL wrote:If that's your car in your sig I'm gonna have a hard time believing money doesn't flow in..
haha im sorry, i guess money flows in...but slowly. The only reason my car looks that good is because I've saved half of everything i make. I don't have all that much into my car. I have a stock DOHC remeber. and my cars never even seen a shop beforegigabit240 wrote:Agreed.. im 16 too and my 240 DOES NOT look that great.S13AL wrote:If that's your car in your sig I'm gonna have a hard time believing money doesn't flow in..
the stuff covering the dash. It'll come off it just takes work. If your using an adhesive for the suede I don't think it will bond well unless you get it off. Good luck though! The GPS location looks awesomeFolkertSX wrote:what do you mean by vinyl? and how would it be removed. it was hard and brittle
yea ive been following your build. did you cover the dash in one piece? i would emagine that to be very hard. I have to stitch mine either way because of the gps cutout. i also have 3m super 77, broadfield told me its not realy good though, and a much heavier adhesive is better. I think i might try spraying the heavy stuff of the dashboard, and then the misty 3m stuff on the back of the fabric. that way it wont bleed through.omgshawn wrote:I'm almost done doing my whole interior in black microfiber suede. All I did was prep everything with 100grit and a wash to remove residue..haven't had any problems yet and it's been on there for over a month. I used 3m Super 77 adhesive. Check my build thread for pics
Hell, I'm 19 and I wish my car looked like his car...gigabit240 wrote:Agreed.. im 16 too and my 240 DOES NOT look that great.S13AL wrote:If that's your car in your sig I'm gonna have a hard time believing money doesn't flow in..
yea im going to do black stitching on the red suede. should be pretty cool. let me know when you get yours doneomgshawn wrote:redoing it this time with a HUD dash and red stitch on the sides/cluster 'hood'/doors
haha i thought of that. its not that far away. I sit pretty close to the wheel, idk about youRedevil wrote:you need to move it forward b/c you will have to reach hella far lol
i already removed that vent. I had a water temp gauge where the vents were. I'll be relocating it to the bottom of the a-pillar using fiberglass. I still have the ac controls. Those are right below itHoffman5982 wrote:quick question: are you removing the ac? If not, where are you going to put the center vents and ac controls?
zenkistic wrote:can you remove it easily? in case you need to update the maps...
the crack at the top is so i can stick my finger in there and remove it. so i kinda need that. when its in the car you cant even see it unless your a midget. that way if i have a long address to put in or something i can take it out easilydiggles240 wrote:do not forget to fill the crack at the top of the screen
i buy all the materials at autozone. theyre good enough. idk if id use it to build body kit but unless someone punches my dash it'll be fine. like i said i already removed the center vent. I just use the side ones. and yes suede does fade. ill be covering my windshield with a 50% tint and the rest of my windows with 25%. this should help greatly. if it fades w.e. ill probably cover it again in a different material. If my dash goes well im going to attempt covering my bucket seats also. Black suede inserts and red suede outside. stay tuned!krash wrote: Hell, I'm 19 and I wish my car looked like his car...
Good fabwork man. I've always wanted to do this but never had the materials. Are you going to relocate the a/c vents or just get rid of them all together? Also, suede does fade in the sun right?
i talked to him and he helped me out quite a bit. this was all before i started the gps thing though. he gave me some tips on stitching it all together though. plus i have my grandma to help me out!Chris28 wrote:Nice dude, it looks like it's going to turn out well. even if there are some imperfections it in, the suede will cover it up. Maybe broadield will come in here, he might have some suggestions.
i installed it to make sure nothing was in the way.RustspecS13 wrote:One thing to make sure is your GPS isn't going to hit the HVAC, or were the center vents used to be?
~Alex
well i can take it out easily if i have to put a address in. ill be using it so rarely anywayscharat wrote:wouldn't that be a little hard to reach? i mean its touch screen and all right? it seems a little TOO set in to me. but it looks pretty good. i don't like how the roundness of the tomtom still kinda shows. oh and what kinda of fiberglass are you using?
