96 Block
Arias 8.7:1 Pistons (stock bore)
Eagle Rods
Clevite Rod & Main Bearings
ARP Head & Main Studs
New timing chain, distributor cap & rotor, all new sensors
Accell Thundersport wires
NGK BKR7Es
MSD 6A, Blaster 3 coil
96 Head
BC Stage 3 cams
BC .5mm oversized valves
BC dual springs, titanium retainers, seats, seals
JWT Adjustable Cam Gears
S13 intake manifold with emissions removed
JGY Top Feed fuel rail
JGY 72# Injectors, with JWT injector resistors wired in
Walbro 255
Nismo Type B FPR
N62 MAF
Enthalpy tuned ECU
Innovate LC1 wideband
Precision 6031E turbo
tial 38mm 10psi external wastegate
There is more, but I figured that is mostly all anyone would question to try and troubleshoot this problem. Here is a link to my build thread if you would like to see the whole build documented and pictures of everything: ken-s-91-fastback-resto-ka-t-build-t535618.html
I recently got it together and ready to start. Got it fired up for the first time but did not have a fuel pressure gauge. It was running rough, and I just adjusted the FPR and got the timing where it needed to be. The next week I got the gauge, hooked it up and was getting 55psi at the rail, too much. I started it up and it ran, although smoking, and when I gave it gas it was choppy and eventually stalled. Tried to start it again and it would crank free but not fire off. Pulled the plugs and they were wet with fuel. Drained the oil and had a lot of gas in my oil pan...
After changing the oil and plugs then letting it sit and air out overnight, I started it up and adjusted the fuel pressure down to 43psi without vacuum, and got the timing set at about 20* BTDC. It will crank fine and fire up with little effort. It idles smooth right around 1000rpm, and with it idleing I am getting 20psi on my oil pressure gauge and 40psi at the fuel rail. But at idle the wideband is telling me 10.1...SUPER rich. If I rev it it leans out to about 12.5 at roughly 3k but I have not taken it any higher. It only ran maybe 2 minutes before I shut it down and pulled the plugs. Once again all 4 are wet.
Pulled the injectors out of the manifold and there is a little fuel on top the rubber washers that sit in the manifold. With the injectors out I switched the key on, heard the pump run, but they did not leak any fuel. This is where I stopped to come seek help, I do not want to keep messing with it and risk grenading the new engine I just spend countless hours and dollars building.
I am kind of at a loss. The MAF sits at damn near 12" exactly from the turbo, and the pipe is a 45* piece. My gauge is telling me 40psi at idle which if anything is a little low. I am thinking bad tune, but is it common that an Enthalpy ECU is that far out that it would be flooding my engine? I need to head in to work so can't do any more today, I was going to extend the intake pipe to get the MAF atleast 16-18" or so away from the turbo and see if that made any difference. I also have a SAFCII but have not yet installed it and do not know how to make adjustments using one, so I haven't messed with it.
Please help me figure out where I should go from here fellas. Any help would be GREATLY appreciated. Thanks in advance...
EDIT: Two questions- I am not using an o2 sensor, I replaced it with a wideband. Would this throw off the ECU and make it dump fuel? Also, when I wired my n62 maf I spliced the two ground wired from the plug together and soldered to the engine harness. I read people doing this and having fine results but could it be that I need to ground one to chassis and the other to the harness?
