fpr
big monkey racing
Car: 1990 240sx
my ministock 240 is running rich and come to find out with the fuel cell they put an walbro 255 in line pump and its putting out too much pressure and blew out the stock regulator. Does someone make a regulator to take it from 55psi to 35psi, or should i put a diff pump and if so wat pump. mjust be in line
driftneil
Car: A pile of cars.
Do you have a stock rail?
mt05
Car: 240sx
stock rail or not, put in an adjustable fuel pressure regulator?
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
buy a adjustable frp, there not expensive
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
there are a few made that will work for your aplication...i got mine from summit..or jegs online for 80 bucks..but im runnin 8AN fuel lines..you can easly get one for 30 to 45 bucks that will alow you to controll peek and idle volumes and pressure..good luck.
big monkey racing
Car: 1990 240sx
will it be in line or bolt on to my stock fuel rail?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
big monkey racing wrote:will it be in line or bolt on to my stock fuel rail?
You can buy a Nismo adjustable FPR that is a direct replacement for the stock FPR, or you can get an adapter to run an inline regulator from Sard or Aeromotive.
The nismo unit is by far the simplest, and they only run about $100.
big monkey racing
Car: 1990 240sx
do u know wat the site to order it is?
!Zar!
Car: Countless.
Either buy another stock fpr, or buy an adjustable one and a gauge.
Your best bet is to sell the fuel pump and get a stock pump/fpr.
Why does your car have a fuel cell?
Vegascorbin
Car: 1990 240sx dirt track race car
As the OP said "MiniStock" I would assume it is a race car.
