found the perfect VH45 valvetrain setup
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
defrag010
Modified by defrag010 at 11:59 PM 2/2/2008
Ezekial
Car: 2001 Nissan 200SX S15
Quote »The stock spring is almost in coil bind with just stock lift[/quote]How so?
There is a good 3.18 mm safety margin going off factory specs and your previous measurements
Which explains why you can run a 60 thou shim and still have at least 1.5 mm safety. No?
Good find on the springs!!
BTW the GTiR inner springs inside radius aligns with the factory radius on the VH45 retainer. No need to machine
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
so would that allow for more power on a N/A VH45 without any other mods, or would it require a cam regrind?
defrag010
Ezekial
zero lift coil bind as in solid height yes?
and yes 60 thou or roughly 1.5 mm safety as i said above
pics of inner springs will be coming soon when i take the last 3 main bearings up to taree and pick up my conrods
defrag010
defrag010
Modified by defrag010 at 12:00 AM 2/3/2008
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Could you provide the required dimensions ? I'll draw up a nice tech drawing to get some custom made.
defrag010
Mettler
Good work defrag, it's going to be mean when you figure out a mint combo of OEM parts that'd be a suitable upgrade ! Should be pretty cheap too aye !
defrag010
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
it looks like a little careful work with a 'dremel tool' on the rocker will solve the slight interference. Make it a smooth long radius relief and it should not be a problem.
Whoever said NICO doesn't have any good "tech info" can kiss my a$$.
Hear that [other nissan forums]?
GREAT work, guys!!!!
As soon as this all comes together, it goes in the articles archive - NICE!
defrag010
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
What about the pistons with that much valve incursion into the cylinder?
defrag010
Q45tech
Is valve lift [0.39" or 9.9mm] a real problem with such oversized valves [1.5"]..........isn't real problem duration [248] and the lack of overlap to create smooth idle and emissions. The peak curtain area [.39/1.5 =0.26] seems ideal except for the restriction in the valve diameter and intrusion of the guide.
By tuliping the intakes [and guide intrusion] wouldn't you accomplish the same flow increase.......is the exhaust flow insufficient after port work?
I love the fact they made these engines work and last with only 120# springs.
The dadburn problem of having to lug the engine down to 1550 rpm [47 mph] with AC on up a tiny incline [common US situation].
elwesso
2007 BMW M Coupe
If you are going to the trouble of doing cam work, wouldnt you want to run more lift as well as more duration? Especially if we can find a way to add meatier springs without a ton of custom modification.
defrag010
Modified by defrag010 at 12:01 AM 2/3/2008
defrag010
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:I love the fact they made these engines work and last with only 120# springs.
Which adds to the engines durability and quietness.
Don't think 1550rpm lugging will be possible with radical timing changes. without multiple dynamometer runs, one is just guessing what gains will be made, and at what price in terms of engine longevity.
defrag010
agentandy
Car: 91 240sx coupe, 95 silvia, 89 supra
nice lab work.now only if cams were readily availble
elwesso
2007 BMW M Coupe
im getting close to buying a set of heads and having you make a set of cams for me!!!!!! ready to bolt in!!
Jerminator96
Car: 94 Chevy Camaro
Any word on the make of those offset keys?
defrag010
defrag010
Jerminator96
Well that's great, SBC springs are a dime a dozen. Of course, most of us don't really have a machine shop at our disposal. Maybe you could tell us how long all of the machining takes so we could get an idea of cost?
That's good news though, i'll be happy to have some more good old american muscle in my motor
defrag010
Modified by defrag010 at 12:02 AM 2/3/2008
Mettler
Once this is all working, my question to you is whether I'll be able to do this stuff to my JDM spec VH41DE ?
I might have a bit of a compare of the part numbers in the valvetrain between VH41DE & VH45DE.
Return to “VH45DE / VK45DE / VK56DE Forum”
