jamestgk »
https://forums.nicoclub.com/jamestgk-u35742.html
Sun Jul 29, 2007 5:01 am
SORRY guy's, been hectic at work have not looked at the computer. first of all yes, they are spring clamps(tomatoe, tomotoe) found at your local auto parts store. i used a spring compressor to get them compressed to install the clamps. even with the wheels on and the car and on an alignment lift, the coils are to far apart for the clamps to go on. yes, be VERY CAREFULL if you are novice. even some low budget shops may not have a high spring rate compressor to do the job. once you get the clamps started you can take off the compressor.
as for adjustment, what you see is full rate compression. meaning the coils are touching. i could back them out more up to an inch. i LOVE the ride so i wont be doing that. at full rate you can add another nut for locking purposes. if you dont use the second nut i suggest lock wire or a weld bead to secure nut.
the tien look good in the photo but no drop on the car's front. also you said in the thread the ride is softer, you must still have the same roll. it looks like you have two fat chicks in the back.
