Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Mon Dec 26, 2005 6:50 pm
Don't worry about the springs. They will cost power, and accelerate cam wear. Just get a good set of cams and concentrate on the bottom end. A little bit of a port job couldn't hurt, but KA heads flow very well for stock (which is why I only port matched with a three angle). The pistons are first to go (unless tuned correctly, and then for safety's sake only to about 350). The rods some people have reported being good until 500HP, but expect to change them with forged units (again, for safety's sake) for 400. Basically you will be making 100HP per cyl, use forged components. You will be going a lot further than I intend, so you need to talk to Fiznat and WDracing. I know for sure that Fiz has made that kind of power. Basically, my answer for you is talk to those two, forged bottom end components (the crank is forged and supposedly good to 500HP, although I have seen 638HP on stock crank), good cams and just help it breath a little better. Also a custom short runner intake manifold is supposed to do a lot of good. Finally, I have seen someone with a wicked 'XS' logo on an aftermarket mani that someone is finally producing for the KA (it looks like one from an SR), someone on the board has one, just ask Fiz, he will know.
