Iamjohnhayes wrote:well actually when it comes to intercoolers the loss in power is more so due to pressure drop. on my friends intercooler on his first gen eclipse (its about 30 x 15 x 4 its huge) the boost would read about 20 lbs on the compressor housing yet if you took the boost off of the intake manifold it would be around 17.
Sure, a lot of people don't know this but that pressure drop (assuming no leak) can be expected to an extent. Sorry if you know this already.
There are two ways to make pressure. 1) by forcing more air into a given space(good) and 2) by heating the air in a given space (bad). Actually you can reduce the space too but we aren't talking about that here.
Anyway, any two, temprature, pressure and volume will varry directly if the third is constant. In this case we take a given volume for simplicity, say one IC full and we cool it by 15% the result will be a pressure loss of 15%. Ever see a baloon go from a boiling pot to a freezer or visa versa?
So, I guess we can figure that 15% of what that turbo is producing is being given off as heat which is ultimatly lost energy. But not much.
Of course you could have a restrictive IC too, but the theory still holds.
Since one turbo might produce more heat at 20lbs, we would have to measure after the IC. Then we could truely say how much net boost the piston sees. I'd even say measure at the manifold. Doing it this way, I'd be interested to see how much difference there would be with two constant and equal manifold pressures and tempratures.
Trouble is, people measure boost at the compressor housing. I'm gunna go from manifold to wast gate and gauge. Then I'll be looking at true boost, not heat boost.
