Doomed2Walk »
https://forums.nicoclub.com/doomed2walk-u8137.html
Fri Dec 03, 2004 12:54 am
Get the kouki. See if there are any mechanical problems and find out why they're selling it for 5.5K, if there are no problems, scoop it up NOW! Kouki is newer, so less rust, also much rarer, and if you do buy it for 5.5K, you can probably resell that on e-bay for 8-9K easy. If the only reason you're deterred is because it's automatic, if you have the money to do a SR swap, you will be able to afford doing the manual conversion along with it.
