dsylvia wrote:I dont know much about which domestic trannies are which. but i would assume there has to be a manual transmission with the same bolt pattern as the c4. or did all the vehicles equiped with a c4 only come in automatic?
A C4 will only help you compared to manual if you are drag racing and cannot shift consistently fast... or have a bad transmission. If you want a shifter kit for a manual, I believe Greddy sells a unit & there may be others.
The C4 is traditionally only used as a drag racing transmission. That's why I asked about the downshifting - I'm planning on using it for other purposes and was hoping that downshifting doesn't make a HUGE weight change/disruption like an auto transmission going from OD->3 or 3->2.
The C4 is not really an automatic transmission, you have to shift the gears yourself. It's like a sequential... but not the dog ear kind you see for rally racing.
****EDIT: I guess the C4 is classified as an auto transmission... So I guess the internals are built w/ reference to auto's we see in modern cars, and not some weird clutchless mechanical thingamabobber?
