Greek.intuit wrote:Clipsed, I like what you've done, and honestly, it looks good as far as theory, but are they going to be pointed in the right direction?
Either way, I have a couple thoughts as well, and have actually started to look into maybe fabricating an eyelid that would just sharpen the headlight and leave some of the side exposed to look more like a BMW. Also, there is supposedly a plan for an HID set for the Tiida in Japan made by the same people who design the Civic HIDs, so I may suggest looking into how that is designed as a basis for what can be legalized...
Otherwise, great job, and let me know if you'd be interested in talking stereos since I'm thinking about integrating a nav system to change around basic parameters for headlight control. Maybe even set up a dual stage lighting setup with the HIDs...
Yes they will be pointed in the right direction and fully adjustable just as any head light is, that is why I am fabricating and designing the mounting plate.
The eyelid for me is cake since fiberglass on a level as small as that is cake. I really don't need to look into anything as a basis on what is actually legalized as you are implying, I believe you are implying since those will be legal, I should base my design off of them?
You have a fine idea, but it is flawed. Japan is RHD in which the HID's in RHD countries are designed differently as to not blind the oncoming traffic on the LHS and not the RHS, now there are some HID projectors that have the ability to switch to both, or even be modded to be the opposite, but some just absolutely can not be modded no matter what. The reason I choose the projectors I did is because they are legal here in the states, and properly installed and adjusted will not cause anyone to be blinded, and will be a very bright light yes, but it will have a wide beam pattern once I mod it to certain specs, and that is what will up this project even more to be a one-off mod!
I am always interested in talking about anything. What exactly do you want to change parametric wise with your nav system for headlight controls? Dual stage setup? With halogen and HID's or what?
