For Mckinney Motorsports: DP clearance on S13
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
These are pics of the Mckinney 3 inch DP and the clearances when mounted on an S13 240 SX with Mckinney mounts:
Very good product, excellent bend and welds. I had pointed out that I think it could be about an inch shorter that would free up some ground clearance.
So, see below:
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
NISMO_RB25
Anyway, the pics probably don't accurately represent it, but basically I think that taking 1 to 1.5 inches off of the pipe would probably place the cat back in the factory position and still leave about an inch of clearance under the floor pan.
FAST-DATSUN
This is a RB25DET with our mounts????
S13Sil-line
Car: Full throttle-*** out sideways
That thing hangs low! If that was on my 240 it would constantly hitting the ground.
S13Sil-line
No offence mack. Just an observation. Is that how its supposed to be?
NISMO_RB25
FAST-DATSUN wrote:This is a RB25DET with our mounts????
This is an RB25 with Mckinney mounts and driveshaft. The motor sits perfect and I don't have any clearance issues. Always been very happy with your products.
I had shortened the stock RB25 DP by about an 1 1/2 inches and it gives me similar clearance to your 3inch pipe.
I really like it, but it just hangs too low.
Blackie9900
hoe come i see red x's on all the pics that are attached and get this error\ ??
File attachments can only be linked from the message board server; Outside linking is not allowed.
Your referrer: http://www.nissaninfiniticlub....84070
» Go Back
FAST-DATSUN
on our proto-type car it not that low. I will check it out and make the necessary adjustments. We doing our new RB25 power Drift car for D1 and Formula D next year so I have some thing here to test on.....
NISMO_RB25
I think I will run it by a welding shop and get an inch chopped off to see how that makes it fit.
Bluefire
Hmm I better go out and check on mine...
-Bluefire
dekand
Car: 1995 240sx SE
i get the same referrer error.
FAST-DATSUN
I just test fitted 3 on a customers car and only had 1/2-1 inch of clearance to the floor and pipe was even or at the most 1/2 inch down from the frame rails. can you get me a picture with our trans mount in it for a referance see our attached pictures.
FAST-DATSUN
picture 2
FAST-DATSUN
picture 3
FAST-DATSUN
AS you can see from the pictures the pipes we test here on the car we very differeant tham yours So we need to find out what happen. PLEASE Call me so we can find out why your pipe is so low and get the problem corrected. and if you could provide some pictures silimar to what I posted we would be greatful...
NISMO_RB25
I have to do some work on my car this weekend, so I will get some pictures posted for you. I unfortunately do not have a lift, so I have to put it on jackstands, but I should be able to get the pics similiar to yours for comparison
NISMO_RB25
Mac,I finally finished teaching myself how to weld (It ain't pretty, but I am getting there), so I am just going to go ahead and chop the pipe tomorrow and weld it back together.
I know you guys would be willing to fix the problem for me, but it is a good oportunity for me to practice welding. You guys have always been great, and this was probably just an anomily.
Here are the best pics I could get, hope this helps.
