For everyone with.....
All things Altima Coupe.
CoupesRUs
Car: 2009 Altima Coupe
.....lowering springs. Should I have them professionally installed or is it a pretty easy DIY project? Any input would be appreciated!
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
I'm installing them Saturday morning and have no fears at all! So I can get back here and share then.
CoupesRUs
AlexN09 wrote:I'm installing them Saturday morning and have no fears at all! So I can get back here and share then.
Awesome!! Yea I wouldnt say im an amateur, maybe a novice but I think the concept is pretty simple
rcboy514
Car: 2013 VW Golf TDI 4dr 6-speed
2008 A/C 3.5 CVT (sold)
2004 BMW 545i V8 >:-)
1991 BMW 535i I-6
not hard, just time consuming if you are working alone. I think it took me around 4-5 hours by myself and taking my time. Be sure and rent a set of spring compressors for the struts and make sure the springs are seated correctly on the spring pad before you tighten everything down.
YoungCoupe
Car: 2011 Altima Coupe 2.5s Metallic slate
Well here's my input: I attempted installing Eibachs by myself yesterday. I started with the rears because I didn't have spring compressors for the front yet. Rears were no problem, knocked out both sides in about 20 minutes. On to the front. I took out the struts, still pretty easy. Taking out the factory springs wasn't too much of a challenge. But here comes the bad part. I spent maybe 4 or 5 hours trying to compress the new springs and put the struts back together. Tried different placements of the spring compressors, even upside down, just couldn't get the springs compressed and aligned. A big part of the problem was the new springs were skinnier and leaned off center, so the spring compressors didn't fit the struts. Finally gave up, and tomorrow I'm going to get the springs mounted onto the struts at a shop. Maybe I just didn't know what I was doing, no idea, but best of luck to you if you decide to DIY.
Also didn't have an impact wrench, so that was hell. Get one.
rcboy514
1991 BMW 535i I-6
Interesting ^
I can't recall having too much trouble putting the compressors on the eibachs, it required a little more finesse but nothing crazy. Also doing this without an impact wrench would suck lol
your compressors looked like this right?
OP...this thread will be of help to you
eibach-install-how-to-warning-long-post ... 20208.html
YoungCoupe
^+1 Kept that on my phone next to me the whole time
Ya those were the ones.
rcboy514
1991 BMW 535i I-6
hmmm, well you gave it a shot which counts for something lol Hopefully they don't charge you a ton for switching out two springs, should take a pro 30-45 mins to complete I would think.
YoungCoupe
Thanks lol ya it should pretty quick and easy for a pro
AlexN09
YoungCoupe wrote:Well here's my input: I attempted installing Eibachs by myself yesterday. I started with the rears because I didn't have spring compressors for the front yet. Rears were no problem, knocked out both sides in about 20 minutes. On to the front. I took out the struts, still pretty easy. Taking out the factory springs wasn't too much of a challenge. But here comes the bad part. I spent maybe 4 or 5 hours trying to compress the new springs and put the struts back together. Tried different placements of the spring compressors, even upside down, just couldn't get the springs compressed and aligned. A big part of the problem was the new springs were skinnier and leaned off center, so the spring compressors didn't fit the struts. Finally gave up, and tomorrow I'm going to get the springs mounted onto the struts at a shop. Maybe I just didn't know what I was doing, no idea, but best of luck to you if you decide to DIY.
Awe mannnn I really hope I don't run into this problem too!! Post some pics up once it's finished and ill do the same.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
VERY important piece of the puzzle: break the bolt on top of the strut inside the engine bay loose BEFORE you do anything else. Other wise you will hate yourself. Also make sure the bolt is actually broken loose and not just rotating inside the top of the strut mount shredding it to pieces. Not that it happened to me or anything...
turbocoupe
Car: 2009 Altima Coupe 2.5 S
If you can hold the strut vertically in a vice I think this will help getting the spring on and off.
YoungCoupe
I took the struts to a shop and got it done in like 10 minutes. The compressor that the shop had was so much easier to use. I mounted everything back onto the car and took it for a test drive. Handles like a dream :biggrin:
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
no before and after pictures of the drop? how much of a drop did you do?
rcboy514
1991 BMW 535i I-6
eibachs typically drop the car about 1.5 inches front and rear, but they will settle a little lower after a while. I've had mine on for close to 4 years and they have def settled closer to 2-2.25 inches.
Before- (I didn't have the nismo wheels before I dropped it, but gap would have been the same.)
front
rear
here is mine currently
front
rear
AlexN09
Awe man that makes me so excited to get my springs on !
YoungCoupe
Wow I hope mine settle that low. I can still fit like 2 and a half or 3 fingers into the gap.
AlexN09
Hey just finished this install tonight with my dad and my buddy. The rears were really easy and the fronts took about three hours. The tutorial way over complicated the steps and really it's incredibly simply. The only difficult part was compressing the new springs onto the struts in a way that would actually seat onto the strut. All in all I enjoyed doing it and feel proud that I've never let a shop do any work for me!!
I have all the proper tools available to me and if I didn't have an impact gun I wouldn't do it again haha
CoupesRUs
Thanks for the input everyone!! Me and my bro did them all today, just have some bad news. He SEVERED a brake line. Dont ask me how. I shoulda been watching him, instead I was working the other front wheel. The drop is sick but renders useless without brakes lol pics will be up soon!
AlexN09
Ahhhh no man!!!! I was so afraid of my bud tearing the tpms sensor off or something but luckily we were both careful. Get some pics up !
stm37s
'11 Infiniti M37 S
rcboy514 wrote:eibachs typically drop the car about 1.5 inches front and rear, but they will settle a little lower after a while. I've had mine on for close to 4 years and they have def settled closer to 2-2.25 inches.
front
rear
front
rear
That baby looks really good man, luv da stance :bowrofl:
YoungCoupe
CoupesRUs wrote:Thanks for the input everyone!! Me and my bro did them all today, just have some bad news. He SEVERED a brake line. Dont ask me how. I shoulda been watching him, instead I was working the other front wheel. The drop is sick but renders useless without brakes lol pics will be up soon!
Oh no! Maybe you can upgrade to steel brake lines lol. Post up pics of your drop!
rcboy514
1991 BMW 535i I-6
thanks man!
Flyers28
Car: 2008 Altima Coupe 2.5 S
front
Can't wait to drop my car, looks great. Out of curiosity what rims do you have on your car, looking for something similar but defiantly that color.
rcboy514
1991 BMW 535i I-6
Forged Aluminum 19"x8.5" Nismo A34 made by Rays Engineering.
HuyyNguyen
Car: Nissan Altima Coupe 2.5s
rcboy514 wrote: I can't recall having too much trouble putting the compressors on the eibachs, it required a little more finesse but nothing crazy. Also doing this without an impact wrench would suck lol
s
I did mines with just a regular handed socket wrench and it took me about 6 hours to finish lol...I remember sitting there crying in agony
Flyers28
rcboy514 wrote:Forged Aluminum 19"x8.5" Nismo A34 made by Rays Engineering.
Awesome thanks.
On a side note how many of u recommend getting the rear camber kit with eibachs?
AlexN09
Well I just maxed out my rear camber adjustment and I'm still at -1.0 or so in the rear.
stm37s
'11 Infiniti M37 S
lowering springs is a must once I get new rims & tires :chuckle:
AlexN09
stm37s wrote:lowering springs is a must once I get new rims & tires :chuckle:
I finally realized that I wanted to lower first because it'll make your ride that much nicer right away and let you wait until you really know what you want and how much you need to save. Then once you've got that your new wheels will look great immediately and you won't have to drive around on big wheels at 4x4 status haha.
