qsiguy wrote:The lights still turn on with 12 volts and ground so it's do-able.
Oh, still certainly do-able, I agree!
It is just a bit more complicated because the "instruction" to energize the relay is "sent" from the switch connected to one computer module to another module in the eigine compartment via the CANbus which then turns on the relay for the light. Very unlike the far simpler diagram that you showed for the 1998 - 1999 Q! Simplifies total wiring in the car a lot in new cars.
So, in today's new cars, there is more wiring involved if you want the existing switch to turn on the fog lights without the various computer modules getting unhappy (they "watch" for the presence of the fog light switch and the main light switches, etc.)!
You pretty much have to re-wire a separate set of wires from the switch to the light, with a fuse, etc., to make it work cleanly. Or unhook from the various computer modules and connect the switch wiring to the relay - may need to add wire to new cars today
Very good info from you on the 1998 - 1998 Q, regardless of my digression on new cars!
Z
