CRyan wrote:
Look on "Trojan Batteries" website - I was just talking to a distributor the other day, for the same reason, he has a batter that is roughly 4 in wide and 10 in long that produces 700 CCA, and is 12v. Its what harley davidsons are about to begin using. I know oddessey battery also makes a small one like this that produces the CCA.
Hope that helps some!
trojan batteries are amazing batteries, but you have to be sure that of the batteries you buy from them because im guessing most of you guys want a maintenance free batterry and most of trojan's stock is wet-cell batteries where you have to maintain the water levels in each cell about once a month. something even just like this may run you into the 150$ range easy, and for a maintenace free battery(aka gel) you may be looking in the 200$+ range.my comment stands,odessey batteries ftw! Dimensions are LxWxH pc535-$135.99 (6.7"x3.9"x6.125")pc545-$139.99 (7"x3.37"x5.17")pc545mj-$149.99 (7"x3.37"x5.17")pc625-$109.99 (6.7"x3.9"x6.89")pc680-$145.99 (7.27"x3.12"x6.67")pc925-$185.99 (7.05"x6.69"x5.79")pc1200-$215.99 (7.87"6.66"x7.55")*the number after the pc part is how many Cranking amps the battery comes with outta the box
Like i said before i can cater to anyones battery needs. Just post a question and i'll help you as best i can!
