AZhitman wrote:'05 4x4, 107K miles.
It's noticeable when accelerating from a stop, sounds metallic, almost like a heat shield flapping against something (doesn't match wheel speed, random).
Also, decelerating / coasting, you can hear it (clutch depressed or in neutral), sounds like it matches wheel speed.
Started recently, has gotten worse (more noticeable) of late.
All 4wd components are electronically actuated.
Have you jacked it up to check for anything loose in the front suspension? Wheel bearings and the like. See if locking it in 4wd makes it go away or get worse.
I am also interested to hear it via video or whatnot.
Its a possibility that you blew up one of the hub springs in the clutch, but I think clutch actuation/feel would have suffered.
Could also be an issue with the brakes. So many options, hard to narrow it down without being able to accurately tell where its coming from and when.
Not that I don't trust you guys, but boy, if I had a dollar for every time a customer told me they had a noise coming from the back or left, but when I drive it, it was obviously coming from the front or right, I would retire. Noises really echo around cars, and it takes a trained ear to chase odd noises, especially if they are intermittent.
Try opening all the windows (yes, I know its hot out) and drive down a residential street, preferably with cars parked at the curb. Try to recreate the noise. Shut the right or left windows alternatively and see if you can determine a side. Stick your head out to see if its from the front or back. Knowing a general location will greatly help narrow things down.
