charat wrote:
uhm... floating valves are actually common on 240sx's. all that needs to happen is a spring or two wearing out (not enough push on the valves themselves) bent valves are a less common problem. the only way a bent valve can occure is if the combustion cycle misfired and bent teh valve. a spring wearing out is much more likely. also, my engine is in fine condition. only problem is the floating valve. (i think there are only 2-3 floating)
You should check your sources.
The valve float that is common is caused by over revving, and it only occurs at higher RPMs.
Valve springs dont often wear to the point of allowing the valve to float off the seat unless an engine is severely abused. More often then not they break before they wear out. Ive seen a handful of Ford V8s come in with broken springs, with less than 150,000 miles on them.
There are a number of ways a valve can become bent. Foreign objects, incorrect timing, timing chain failure, or last but not least, floating the valves into pistons via over revving. If someone did float a valve into a piston, then it is likely bent.
Not to mention a bent valve is not the only thing that can cause a leak. As l_c stated, ovaled valve seats can leak, as well as burned valves.
It has been mentioned that you need to find a new mechanic, this may not be true. I would find it much more believable that one of two things happened. Either you misunderstood what he was saying because he was being too technical for you, or because you weren't listening. Or he attempted to dumb it down, and accidentally used incorrect terminology to explain it to you. I would bet, given the chance to explain himself here, things would be much clearer.
Come to think of it, we are trying to help solve your problem, buy you have yet to actually tell us what the symptoms are. Its tough to diagnose a problem based on hearsay. Especially when your info does not seem to add up.
Is it ticking?
Is it lacking power?
Is it consuming excessive fuel?
Does it smoke?
Does it smell?
Does it run rough?
Is the problem better or worse at idle?
Is the problem better or worse at mid RPM?
Is the problem better or worse at high RPM?
Is the problem better or worse at a constant cruising speed (60 mph)?
Just for future reference, try not to talk down to those attempting to help you. Especially when you are just repeating what your friend told you.
You weren't even in high school when I bought my first 240SX
