texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Sun Dec 30, 2007 6:17 pm
The operating pressures in the active suspension system are very high, and when driving on flat accumulators go well over 5000 psi over bumps.
Normal operating pressures exceed 2000 psi. 'Cheap' tank valves have low pressure,low cost valve cores which may fail explosively ( becoming a bullet) when the charging hose is removed.This is why I use only certified aircraft quality valves, purchased from aircraft parts supplier. I have good assurance they are not counterfeit parts from who knows where, made to who knows what specification with no Q/A.
