Thanks man!
went to nissan, ordered all OEM flywheel, clutch cover, and bell housing bolts for a KA as they're all the same.
Got the transmission on, but noticed the pig ear brackets dont have anywhere to bolt up to the AWD block. anyone verify when using RB26 block with RB25 trans if these brackets are used??
http://shop.rawbrokerage.com/images/122 ... 30120.jpeg
I need to still find
- driveshaft bolts - bought
ARRIVED & INSTALLED -power steering pump bolts - bought & installed
ARRIVED & INSTALLED -bell housing to cover plate bolts & nuts - bought & installed
ARRIVED & INSTALLED -RB25 dipstick
-EBAY SR20 downpipe
order clutch master cylinder - tried to bleed clutch... no luck. i think its shot.
A32 Maxima insulators. part# 16636-72P00 - Dealership (for injectors to manifold)
Ground cable on alternator
power cable 4ga through firewall to dist block (autozone)
ARRIVED & INSTALLED working on the head drain, i need a -4 to -12AN adapter for the drain hose to clear. (will pick something up tomorrow hopefully)
check clutch release bearing / fork / wedge collar assembly... i think something isnt settled right with the pull type pressure plate, bearing deal. anyone know the correct installation method for the clutch and trans? i put the flywheel on, then clutch disc and cover with wedge collar pulled up, no bearing attached. bearing was left with fork and sleeve inside trans, then put on. is this correct?
Now i went to go put my driveshaft on and with the yoke all the way in the trans, the diff side where it bolts up has a huge gap. Im not sure if i've got a spacer missing or something. its an aluminum non-abs driveshaft shop driveshaft. anyone help?
Still waiting on my raw brokerage shipment on:
ARRIVED & INSTALLED -cam seals, front main seal
ARRIVED & INSTALLED -upper and lower timing covers
ARRIVED & INSTALLED -thermostat
